What do I do if my amplifier only takes 4ga wire max, and I get 1/0? Can I just trim the wire up some so it'll fit or will that somehow short the connection out or something?
-John
Edited by ILuvJDM
  • Replies 65
  • Views 5.3k
Personally, I'd get a distribution block to size it down, or at a minimum, use a 1/0 to 4ga reducer.
x2 if you have or plan to run another amp in the future, you wont have to buy a distro for it :)
so you're saying I should for sure get a distribution block? Will trimming the wire lower the build quality of the project and affect something in the long run? If so, I'll get the distribution block, cause a $20 part isn't worth sacrificing the quality...
-John
-John
Bump for an answer so I can order this kit :dancing:
-John
Trimming the wire will not hurt anything. Don't trim a 1/0 to 4ga or anything drastic like that...but if you have 1/0 inputs and your 1/0 cable wont fit, it's perfectly fine to trim it a bit.
the biggest size accepted on the amp is 4ga. I'll get a distribution block then to be on the safe side. That'll leave room in case I ever upgrade the front stage and need to power another amp
-John
ok, well I thought I had it figured out until I looked at all the options for distribution blocks...
from this page, which do I need?
http://www.knukonceptz.com/productMaster.c...0Fuse%20Blocks#
I'll be using 1/0 wire that will be sized down to 4ga to power a 600watt amplifier, and may possibly use another amplifier in the future so it needs to have at least 2 outputs
Edit: I would need this right?
http://www.knukonceptz.com/productDetail.cfm?prodID=KNF-12
which size fuses should I get with the distro block?
also, which size fuse should I get for the regular fuse by the battery?
-John
Edited by ILuvJDM
-John
im using hte konfused (2nd choice) block myself. i liek it :) goonna get the digital distro later on the line
read for fuse size
http://www.bcae1.com/fuses.htm
read for fuse size
yeah that's the one I'm going to get
I've read that page about 10 times now and I still don't know which size to get? If the maximum size for 4 ga is 125, then should I get 100amp fuse? Since the block has 2 fuses should I get both of them the same size (two 100amp fuses)?
and when the wire says "1/0" I'm not sure which number to use in that chart; 1ga or 0ga? Would getting a 200amp fuse for the main power wire be optimal?
-John
the size on that site is the MAX you can use. a 250 or 200 for the 0 gauge would be fine and im usin a 80 or 70a (i forget) with my 4 gauge main wire. 1/0 = 0
alright thanks man
-John
