Posted June 10, 200718 yr I had some one building me a box, but they ended up not ever repsonding back and now I stuck without a box for my 15" Q. Do you guys think this box will be good solid box to house my Q?http://cgi.ebay.com/ws/eBayISAPI.dll?ViewI...p;rd=1&rd=1
June 10, 200718 yr "Slot-Port Tuned @ 32Hz for MAXIMUM "LSQ"!"HAHAHAYeah...its ok. Not great, but ok.
June 10, 200718 yr Hmmm Thought you needed TS specs of the sub to tune correctly (Xmax, Displacement etc) ??Eh i guess so for a "ballpark" tuning Edited June 10, 200718 yr by theabunai
June 11, 200718 yr Should be alright if they on with their tuning. Dont need TS params to tune an enclosure as the enclosure net volume, port area, and port length are set regardless of sub TS params... now how the sub will act in that space is why you need the TS params to graph out the response.You will need to open the hole up slightly as I believe the cut ID for the 15s is 14.125"... Thanks,Scott
