Posted June 11, 200719 yr i want to lower my tuning in one of my enclosures2 each 4 " aeroports how close can i bring them to the floor or what is the minimum space i need to leave from top of floor to bottom of ports Thanks
June 11, 200719 yr Author An inch or so is fine.that would be good news for me than not sure why, but i thought 2-3 inches of space would be needed so 1 inch space would be as low as one can go , or a close as one would go thanks for the fast response 350zspl Travis
June 11, 200719 yr Most people that have downfiring woofers/ports leave 3/4" to maybe 2" of clearance, that's really all that's needed.
June 11, 200719 yr Author nissan 2006350zt40001bd1 each trf2212 12" team rf sub3 cubes1" mdf2 each 4" aeroports woofer and ports are face up not using sub down firing right now box is tuned to 45 i wanted to lower tuning so i wanted to add as much length to ports to gain the lowest frequency possible with this set up so if i go ahead and lenghten port to the max i can i wanted to know exactely how much clearance i must leave from the bottom of port to the top of the encl;osures floor does my ? make sense , am i explaining correctly thank again JIm350zspl
June 11, 200719 yr Oh, when you said "floor" I thought whatever you have the box sitting on, not the bottom of the box I'd say 2" is fine, but you could always use elbow joints to extend the ports. Or use external ones.
June 11, 200719 yr Author actually can't use external in my situation distance from port to inside of hatch is to close to externally port but i have 4" of space from bottom of ports to enclosure floor so if i leave 2" for space i can still extend ports by 2 " each at this time which will make tuning lower not sure how low but lower thanks for all your time
