Posted June 12, 200719 yr is there any relation?ie. would two subs showing an impedance of 4 ohms have a better chance at SQ than two subs showing 1 ohm
June 12, 200719 yr Theoretically, it changes the damping factor of the system - which is the ratio of the amp's output impedance to the impedance of the load.Most push/pull solid state amps have such low output impedances that lowering the load impedance doesn't do a whole lot to change DF.The short answer? Don't worry about it.
June 12, 200719 yr Author Theoretically, it changes the damping factor of the system - which is the ratio of the amp's output impedance to the impedance of the load.Most push/pull solid state amps have such low output impedances that lowering the load impedance doesn't do a whole lot to change DF.The short answer? Don't worry about it.it sounds like you're saying it is possible but it depends on the ampwhich might suck for me cause i was thinking about getting the Hifonics BXi1606D and running it at 1 ohm
June 12, 200719 yr Damping Factor is a stupid spec anyways...The driver design is what determines its cone control.
