Posted June 16, 200719 yr honeycomb polymer w/ Kavlar coated cone, 1000watt RMS, 21Lb Motor for 07' T/S parameters: REVC: 4 ohms FS: 34hz QES: .97 QMS: 7.2 QTS: .86 VAS: 3.6 BL: 14 MMS: 241g Sens:[email protected]
June 16, 200719 yr Author the T/S i copied from their web/sitethis is what the regular WMDs look like:WMD15d2 Revc=4.0 ohms (both V.C.'s in series) fs=28hz qes=1.05 qms=7.34 qts=.92 vas=3.37ft^3 bl=15.25 [email protected] Edited June 16, 200719 yr by Lord Baccus
June 16, 200719 yr What's your intent for this? I would guess that it's SPL, but it's severely undermotored if that's the case....
June 17, 200719 yr Author I had these made for SPL...i have allways had subs with Heavy cones and Bigg Motors, so i was thinking if i got a sub built with a really Stiff cone that would take about 1000rms i can over power em by about 500rms each for burps without killing em and get a better SPL # Edited June 18, 200719 yr by Lord Baccus
June 17, 200719 yr it'll be interesting to see if your idea works bro. can't wait for updates!wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
June 18, 200719 yr Author LB...Have you ever run Fi subs?have read great things about them but never seen a Fi sub go Live... was told designer from RE jumped shipp and started his own Co ???they look impressive.
June 18, 200719 yr Author too bad the owner of wmd is a blatant liar ??? Wow Bro thats outta left field !!! i dident hear that from John, someone @ a competition in Ft Worth TX was talking about Fi subs and i was just lisenning in why would you think John had anything to say about Fi ? Edited June 18, 200719 yr by Lord Baccus
June 18, 200719 yr Author Who makes them? I like the look of those cones...http://pierceaudioproducts.com/forum/index.php?topic=3.0http://profile.myspace.com/index.cfm?fusea...2a-5090709f8d20they can re-cone or custom make ya a subb if ya like
June 19, 200719 yr Author mark, how about an 18 with one of those cones ? it can be done Pap has an 18" MOAB with that cone for 07'
June 20, 200719 yr I think the ten's that are being made for me are bigger than your subs, more efficient, and will be quite damn impressive, too bad I won't be seeing them till around november, but I am not rushing the guys working on my subs as I wan't the best compromise between efficiency and power handling, as each woofer will be sitting on ~ 4000 watts rms of amp. My magnets are huge, lol. 10.1" diameter magnet on a 10" woofer.But I am basically paying more than what a normal customer buying the same woofer except for the custom basket and cone would be paying for a 15" version of my woofer. Edited June 20, 200719 yr by audio-neon
June 20, 200719 yr sorry, that came off as me trying to brag. I was just trying to make a point on your comment about heavy cones and large motors.
June 20, 200719 yr Author sorry, that came off as me trying to brag. I was just trying to make a point on your comment about heavy cones and large motors.its cool :0i was just wanting to try something different Stiffer cone / less motor / more powersence im only working with 3000watts i figure the best way to make use of the power i have is go with a sub that requires less power to get up & going. problem with that is all the off the shelf subs are either cone/motor heavy ( need too mush power ), or just the oppisite lite cone /motor ( wont take much power )so i spoke with John @ Pap and discussed using the stiffer cone from the new MOAB on the frame for the WMD w/ the new Motor its good for 1000rms per sub so i figure with a 3000watt amp ill be overdriving em for Burps about 500watts ea.in the same box that did 151db with the power hungry subs, hoping my plan holds water, shooting for a 154db realisticly 153 ish db
