honeycomb polymer w/ Kavlar coated cone, 1000watt RMS, 21Lb Motor for 07'
T/S parameters:
REVC: 4 ohms
FS: 34hz
QES: .97
QMS: 7.2
QTS: .86
VAS: 3.6
BL: 14
MMS: 241g
Sens:[email protected]
the T/S i copied from their web/site
this is what the regular WMDs look like:
WMD15d2
Revc=4.0 ohms (both V.C.'s in series)
fs=28hz
qes=1.05
qms=7.34
qts=.92
vas=3.37ft^3
bl=15.25
[email protected]
Edited by Lord Baccus
I had these made for SPL...
i have allways had subs with Heavy cones and Bigg Motors, so i was thinking if i got a sub built with a really Stiff cone that would take about 1000rms i can over power em by about 500rms each for burps without killing em and get a better SPL # :slayer:
it'll be interesting to see if your idea works bro. can't wait for updates!
wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee :slayer:
  • Admin
:+1:
LB...Have you ever run Fi subs?
have read great things about them but never seen a Fi sub go Live... was told designer from RE jumped shipp and started his own Co ???
they look impressive.
too bad the owner of wmd is a blatant liar :)
??? Wow Bro thats outta left field !!!
i dident hear that from John, someone @ a competition in Ft Worth TX was talking about Fi subs and i was just lisenning in :)
why would you think John had anything to say about Fi ?
Who makes them? I like the look of those cones...
mark, how about an 18 with one of those cones ? :D
it can be done :) Pap has an 18" MOAB with that cone for 07'
I think the ten's that are being made for me are bigger than your subs, more efficient, and will be quite damn impressive, too bad I won't be seeing them till around november, but I am not rushing the guys working on my subs as I wan't the best compromise between efficiency and power handling, as each woofer will be sitting on ~ 4000 watts rms of amp. My magnets are huge, lol. 10.1" diameter magnet on a 10" woofer.
But I am basically paying more than what a normal customer buying the same woofer except for the custom basket and cone would be paying for a 15" version of my woofer.
Edited by audio-neon
sorry, that came off as me trying to brag. I was just trying to make a point on your comment about heavy cones and large motors.
its cool :0
i was just wanting to try something different
Stiffer cone / less motor / more power
sence im only working with 3000watts i figure the best way to make use of the power i have is go with a sub that requires less power to get up & going. problem with that is all the off the shelf subs are either cone/motor heavy ( need too mush power ),
or just the oppisite lite cone /motor ( wont take much power )
so i spoke with John @ Pap and discussed using the stiffer cone from the new MOAB on the frame for the WMD w/ the new Motor its good for 1000rms per sub so i figure with a 3000watt amp ill be overdriving em for Burps about 500watts ea.
in the same box that did 151db with the power hungry subs, hoping my plan holds water,
shooting for a 154db :) realisticly 153 ish db
:domoslay:
