Posted June 19, 200718 yr I am planning on buying two MA Audio HK802SX amps. If someone knows about this amp I would appreciate it if you could tell me whether it is a good amp or bad amp. I have seen the other amp of theirs in action. The guy had it moded and it was putting out over 6kw.
June 19, 200718 yr not a snowballs chance in hell that amp will do 6kwthe hk-4000's wouldn't even do that
June 19, 200718 yr i used to own one of those amp. not even 2 ohm stable. says they are but not really. wouldnt go with that check out rockfords line.
June 20, 200718 yr Author How bout 2 massive audio P3000.1 amps http://www.massiveaudio.comI have asked a lot of people about the massive audio amp and I was getting a lot of negative feedback. I wanted to get two of them.
June 20, 200718 yr Been there and did some extensive testing with that board...Honestly man, save your money up for something better....half of that amp (one board) i was doing good to get 900 watts out of it, and it was not remotely near clean.
June 20, 200718 yr ive got 4 hk4000ds, ill be running mine @ 2 ohm on 16v....should be around 3500ish watts each.but ya thats 802sx isnt gonna do 6k lol
June 20, 200718 yr Author ive got 4 hk4000ds, ill be running mine @ 2 ohm on 16v....should be around 3500ish watts each.but ya thats 802sx isnt gonna do 6k lolI wasn't talking about the 802sx I was talking about the hk4000D. I guy said that he modified his to put out more power. What do you think about the Lanzar OPTI4000D.
