Posted June 19, 200718 yr I have bought a Freeway Blaster for my car. Figured it would be fun to have a little louder horn. Anyway. I cannot for the life of me find the horn under the hood so I can switch it out with the Freeway Blaster. I looked along the walls of the engine compartment, mostly around the battery since I figured thats where it would be. I must be as blind as a bat. So if you happen to know off hand where it is or where online I could go to find out I would be very greateful. Thanks~MadroX
June 19, 200718 yr I would try looking inside the fender. But I am just guessing, cause i don't know what kind of car you have. Or look from underneath the car. You should be able to see it.
June 19, 200718 yr Check where the grill is on the front. You can if you want, have someone honk the horn as you search for it. Might want to wear ear plugs though. Edited June 19, 200718 yr by Don Pisto
June 20, 200718 yr Check where the grill is on the front. You can if you want, have someone honk the horn as you search for it. Might want to wear ear plugs though.You have the right idea.It should be middle to right in front of the radiator where the actual bumper is.
June 21, 200718 yr Should be on the drivers side near the fenderwell cover in front. Get on your back and have a peek right behind the bumper cover. You may have a dual horn setup though which means it will be on either side.
