Posted June 21, 200719 yr I'm looking at upgrading my subs in the near future to a 15" Q. Could someone give me an idea on the outer box dimensions so I can see if a 15 will fit in my 1994 Mazda 626. looking for about the 4 cu. ft. net tuned to 30-32 Hz. I'm limited to about 17" high by about 30" wide. I assume with those dimensions I'll likely have to go with the sub facing up. Is there any potential problems with this? If it doesn't work out with the 15 I'll have to get a 12 instead.
June 21, 200719 yr I'm looking at upgrading my subs in the near future to a 15" Q. Could someone give me an idea on the outer box dimensions so I can see if a 15 will fit in my 1994 Mazda 626. looking for about the 4 cu. ft. net tuned to 30-32 Hz. I'm limited to about 17" high by about 30" wide. I assume with those dimensions I'll likely have to go with the sub facing up. Is there any potential problems with this? If it doesn't work out with the 15 I'll have to get a 12 instead.All in inches Box width :30.00 Box height :17.00 Box depth :22.00 Wood thickness :1 inch Square port area :60.00 Box Volume {ft3}4.048 Tuned Frequency :31.63 hz.If you want i can post the cutting measurements you will need for this box!
June 21, 200719 yr Author Awesome, it should fit in there nicely. I've still got some saving to do before it happens. Thanks
