Posted June 23, 200718 yr Ive got 2 10 inch kicker comps....from around 1995In a box...30 x 12 x 12I know the box is small...and sealed but i wanna get some 10 that get low and loud...not looking to spend more than 350 for a pair..i was gonna use the box till i got the cash to build a ported one for the subsFi SSDTC Sounds OEM10Kicker CVXAlpine Type R 10http://sonicelectronix.com/item_9235...S-W2501D4.html http://sonicelectronix.com/item_7210...0W3v2D2+-.htmlhttp://www.onlinecarstereo.com/CarAu...roductID=16852http://www.woofersetc.com/index.cfm?...t=account_namehttp://www.woofersetc.com/index.cfm?...roduct_ID=3504those are some othersabout a week ago...i was set on 2 mach5 maw15s...but i rehooked up my old kickers in the box..if somebody can convince to go maw..or got FI Q or SSD ported or something elseIM Jus confused and lost...
June 24, 200718 yr what kind of power you got?other subs worth mentioning..soundsplinter rl-i10stereo integrity bm 10rd audio classic 10wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
June 25, 200718 yr Admin The SSD or BM 10" get my vote.If the budget was larger I would shamelessly say the ICON, or add in the Q 10, but they won't make it under.
June 27, 200718 yr The SSD or BM 10" get my vote.The OP said he didn't want to spend more then 350 for a pair of 10s. Where can I find a pair of BMs for $350? My plan of putting my Mag into my new car won't work because of Mouting Depth issues. I'm currently looking at a pair of RLi-10s, but if I can get BMs for less then $400, then I'll go that way.
July 9, 200718 yr I would go with the dual SSD's , but , you won't go wrong with ANY of the above recommended subs. If your budget controls the decesion, go with the ones you can afford. Sometimes, thats the determining factor.... what you can afford.
