Ok so i'm pretty much done wt my box, will post pics soon enough, but.
I'm not going to be able to reach my subs, once done, so if i connect each + and - to a bolt and nut on the box, that should work just fine correct? I'm sure i've seen it done before.
I just would rather not run long lengths of wire to the amp.
Used to use them all the time. Only bolts I ever had a problem with were ones that had some kind of anti corrosion coating on them. :)
Zinc coated :) or galvanized.
That's the ticket , zinc turned black as charcoal :)
I never had a problem with mine, and if you're using 3/8, I have just drilled 5/16 hole and you can screw the bolt in with your screwgun. Just tighten down the chuck and screw in place.
Good luck!
  • 2 weeks later...
  • 3 weeks later...
use bare wire lug terminals from home depot with stainless bolts and nuts. that way all u need is a flat head scew driver to undo connections. no ring terminals or having to use a ratchet and socket. i usually do 2 pos and 2 neg wire the coils directly to them and do all parallel and series adjustments outside the box.
