Posted June 25, 200718 yr im fixing to purchase an o-scope to make sure my q's arent recieving any square waves. im metering the gain with my dmm but i want to be double sure. what kind of o-scope do i need? as in mhz and all that can someone point me in the right direction? thanks
June 25, 200718 yr do something better with your time man, theres no pointThat's your inexperienced opinion.Any o-scope will work, its audio band AC anyways.Find whats cheap, link it here, I, or someone else will let ya know yay or nay
June 25, 200718 yr Author here you go:http://cgi.ebay.com/BK-PRECISION-1471B-10M...1QQcmdZViewItemo and bassplayer, there is a point in my case. please dont jump on my thread with negative comments. o and thanx for seeing my point, ANeonRider
June 25, 200718 yr Both would get the job done... but the second one would probably be easier to use & lighter. Tektronix is the brand I used in school, and use at work.
June 25, 200718 yr Author well some are fairly cheap that are new or barely used on ebay. does the mhz even matter? if so what do i need to shoot for?
June 25, 200718 yr well some are fairly cheap that are new or barely used on ebay. does the mhz even matter? if so what do i need to shoot for?considering audio only goes up to ~20kHz, even just 1MHz is far above what you need
June 26, 200718 yr I don't know where you live, but if there are any amateur radio swapmeets around you, those are usually good places to find a lot of used test equipment, and have the chance to try it out before you buy it. I went to one last spring in Raleigh and there were piles of o'scopes, signal generators, spectrum analyzers, and all sorts of surplus electronic stuff like that for sale.
June 26, 200718 yr I don't know where you live, but if there are any amateur radio swapmeets around you, those are usually good places to find a lot of used test equipment, and have the chance to try it out before you buy it. I went to one last spring in Raleigh and there were piles of o'scopes, signal generators, spectrum analyzers, and all sorts of surplus electronic stuff like that for sale.Do you have any suggestions for where to look for such swapmeets?
June 26, 200718 yr QRZ.com has a subforum for people posting notices here: http://www.qrz.com/ib-bin/ikonboard.cgi?;act=SF;f=6, might be a place to start looking anyway. They're usually clustered around larger cities, once or twice a year.
June 26, 200718 yr http://www.realmofexcursion.com/store/prod...products_id/275I think they need to use a different font for the $185 Also, anybody have any thoughts on this one? I might be looking to get it...not sure what to look for in an oscope as well, though.Edit: This was a double post. Edited June 26, 200718 yr by Big E
June 26, 200718 yr I have a Velleman HPS10-SE. It cost around $160 and is very easy to use as well as being battery powered. Make sure you get the special edition, it has the backlit LCD screen.LINKI am pretty sure that is the guy I bought it from as well.Here is more info on the Velleman site... http://www.vellemanusa.com/us/enu/product/view/?id=521603
June 26, 200718 yr Author I have a Velleman HPS10-SE. It cost around $160 and is very easy to use as well as being battery powered. Make sure you get the special edition, it has the backlit LCD screen.LINKI am pretty sure that is the guy I bought it from as well.Here is more info on the Velleman site... http://www.vellemanusa.com/us/enu/product/view/?id=521603i like that o-scope. its portable and battery powered for a reasonable price. i might just shell out an extra 65-80 for that one since it will do away with a lot of headaches. thanks for the help guys! if anyone finds anything better feel free to post. or just post what you guys use if anything.
