Posted June 26, 200718 yr what is the volume i should port these at, and to what frequency for car usage?also how big of a port should i use?thanks!
June 26, 200718 yr What functionality will be using these for? Home, car, how deep do you need them to extend?
June 26, 200718 yr Author What functionality will be using these for? Home, car, how deep do you need them to extend?what is the volume i should port these at, and to what frequency for car usage?but i dont know i just want some extra mid-bass out of them. probably tune them to 60-70hz or so. lmk if theres anything wrong in that tuning for my application.
June 26, 200718 yr Good luck. Jason made GIGANTIC door buildouts, HUGE... they came out to .54cubesHe tried using a flared 1.5port, all the way up to a 2.5 I believe... and he got noise...Supposedly. I always thought it was just because of the tones he was playing...Anyways. Mine are sealed in ~.2cubes... and I cross them @40hz... active... and they sound great...nG
June 27, 200718 yr Don't be afraid to use a lower crossover point. Especially if you have a 3rd or 4th order slope. I have mine at 50hz and I really like it, but that is totally up to the listener.
June 27, 200718 yr Author yeah noah-i have the same size as you i guess ill go seald Don't be afraid to use a lower crossover point. Especially if you have a 3rd or 4th order slope. I have mine at 50hz and I really like it, but that is totally up to the listener. ill try that when i get thinGs sealed up.thanks yall.dang Im getting a psp. im posting from oNe RiGht now
June 27, 200718 yr Author I'll repeat, IB is your friend.i dont know how i can do IB....my doors aren't set up like normal doors, they have no speaker holes in them.
June 27, 200718 yr I'll repeat, IB is your friend.i dont know how i can do IB....my doors aren't set up like normal doors, they have no speaker holes in them.Cut a whole in your door metal, seal the skin and mount them like you are.
June 27, 200718 yr Author I'll repeat, IB is your friend.i dont know how i can do IB....my doors aren't set up like normal doors, they have no speaker holes in them.Cut a whole in your door metal, seal the skin and mount them like you are. no thanks....crossed my mind when i started planning, but i want to keep my door panels as stock as possible, which is why im doing what im doing. no hole cutting is going on in my doors
June 27, 200718 yr I'll repeat, IB is your friend.i dont know how i can do IB....my doors aren't set up like normal doors, they have no speaker holes in them.Cut a whole in your door metal, seal the skin and mount them like you are. no thanks....crossed my mind when i started planning, but i want to keep my door panels as stock as possible, which is why im doing what im doing. no hole cutting is going on in my doors Umm, are you protecting your "classic" or what is your logic? It isn't like you need that big of a hole, you just need to vent the backwave effectively out of the door so it can't intermingle with the front wave. It will sound WAY better than if you port or seal it on your first shot. My guesstimation would be that you are going to need to build your setup three or four times to come anywhere near the response as one attempt running IB. It will really be a far superior way to mount that driver in your car doors. Way easier on the build as well.
June 27, 200718 yr Author Umm, are you protecting your "classic" or what is your logic? It isn't like you need that big of a hole, you just need to vent the backwave effectively out of the door so it can't intermingle with the front wave. It will sound WAY better than if you port or seal it on your first shot. My guesstimation would be that you are going to need to build your setup three or four times to come anywhere near the response as one attempt running IB. It will really be a far superior way to mount that driver in your car doors. Way easier on the build as well.ya protecting my "classic", just dont want to cut any holes in my car. also if i do, please help me understand. like how big? i just snapped a couple of shots and here are my doors:and where would i cut it? i have no problem cutting through the door metal, its just the door panel i dont want to cut through
