Newly converted to FIcarudio products by xconcepts from caraudio i am wondering what is the min power requirement for the SSD's i will be replacing a pair JL Audio 10w3v2's in a sealed enlosure of 0.65 which are both being powered by a JL Audio 500/1 , and being unfermiliar with the FIcarudio subs , i'm wondering will a pair of 10 "SSD's work properly being connected and boxed the same way ??
The Jl's were rated 300 W each , will the amp be sufficient for these two SSD's to perform properly ?
Will also be adding a pair of 10 " 2 ohm BL's each connected individually to it's own Alpine PDX 1000.1 in a ported enclosure tuned at 32 , will add P chamfer , cooling , Flatwind , and universal , what do you guys think ??
Dan
Dan
I had 400watts each on mine at one time... sounded great.
I recommend a 500/1 on each.
I'd ask for them to be made with soft spiders, My 10's were... so they were able to make more use of the lower power...
nG
Why?
:WELCOME: and maybe start a new topic in the Fi section. :)
If you want noise, 1 watt. Remember, below RMS does NOT damage the woofer AT ALL; clipping and distortion DOES.
Also, what the HELL is with the 2 SSD's sealed and 2 BL's ported?!?!? Do NOT mix subwoofers AND box designs...you're going to get all kinds of cancellation.
Edited by Big E
