I WAS WONDERING IF I COULD FIT 2 15'' BTL'S IN MY TRUNK. IF NOT COULD I FIT 2 12'S? I wanted to build a ported sub enclosure tuned to 32 hz. I ALSO WANTED TO KNOW IF THERE WAS SOMEONE I COULD PAY TO DESIGN ME A SUB ENCLOSURE? AND I ALSO WANTED TO KNOW IF HAVING 1 AMP POWER BOTH SUBS IS ANY BETTER THAN HAVING ONE AMP PER SUB (FOR EXAMPLE 2-2,000 WATT AMPS AS OPPOSED TO 1 4,000 WATT AMP? IF ANYONE COULD HELP ME OUT I WOULD APPRECIATE IT, THANKS, IM TERRIBLE AT MATH. My trunk mesurements are in the following link, I wasn't able to figure out how to post the picture. Trunk specs
Edited by cjack
Depends on your budget and impedance needs, sometimes two amps are better than one, and sometimes it's the other way around.
Just a hint for the future, watch if your Caps Lock is on :)
Sorry about that, ;) I noticed that to after I posted it but you replied to quik. The reason I ask was because I was thinking of purchasing 1 amp and sub first then later adding a second sub and amp or just purchase one amp that could handle both.
Edited by cjack
Meade has 8 Btl on one amp.
Little hint... its made by RF
I wanted to know so I could figure out if i should purchase a dual 2 ohm btl or a dual 1 ohm and what amp i want to combine w/ it.
Edited by cjack
