July 9, 200719 yr CARDBOARD=GOOD TEMPLATES.... thats all i have to say.Don't forget the tape and the tick wheel to trace with
July 9, 200719 yr Author Are you using this for competitions or just really loud daily?i was going to use it for a competitions for next month and for daily
July 9, 200719 yr I'm also looking to wall my car. Not for comps @ all. I want low and for daily.2 XXX18s4 Sundown SAZ-1500s
July 12, 200719 yr I'm also looking to wall my car. Not for comps @ all. I want low and for daily.2 XXX18s4 Sundown SAZ-1500sChange XXX with MT or BTL.
July 13, 200719 yr I had 2 MT15s. Looking for something more musical. Not really worried about putting up high numbers.Thanks tho.
July 30, 200718 yr idk if xxx's can take 3000+ w rms daily is what hes saying.run each amp @ 2ohm and I should be ok.
July 30, 200718 yr $1200 per wall....takes me 3 days WOOT !!!!!!! lolIf you do not know the proper way to build a wall...You literally can kill someone.Please...keep that in mind.When it comes to construction of the wall...If you get in a car accident..If you do not build it poperly....it will chase you down and make you apart of the steering wheel.And of course...the same goes for your passenger if you happen to have one.
