does anybody know the displacment on a fully loaded BTL 15? Thanks
Dustin
Not that critical man..and it's right on the website...
BTL15
DUAL 1 | DUAL 2
Fs: 36.7 Hz | 36.1 Hz
Re: 0.7 Ohms/coil | 1.5 Ohms/coil
Qms: 5.62 | 5.71
Qes: .25 | .23
Qts: .24 | .23
Mms: 241g | 249g
Cms: 0.78mm/N | 0.78mm/N
Sd: 810cm^2 | 810cm^2
Vas: 71.7 l | 71.7 l
Spl: 93.3dB 1W/1m | 93.4dB 1W/1m
Bl: 17.5 N/A | 26.9 N/A
Xmax: 16mm * | 16mm *
Rms: 2000W * | 2000W *
Sealed box: N/A cuft | N/A cuft
Ported box: 3-5cuft | 3-5cuft
Sub OD: 15.625
Fully loaded is 1" deeper than above with the extra magnet and I believe dispacement goes up to .24 cuft.
Thanks for the INFO.
And as far as the post above the one from FI, Im very aware the one WITHOUT the third magnet is on the website, but as I said, I wanted to know what the fully loaded btl displacment was.
Thanks again
Dustin
