sundownz
Nightshade T/S Specs
All specs measured after a short break-in period. Specs will vary slightly from unit to unit and with further break-in, as with any subwoofer, but these specs are accurate enough to model up your enclosures.
12" Model D1 Coils:
Qts = 0.40
Qms = 6.83
Qes = 0.43
Fs = 43 Hz
VAS = 11.7 L
Le = 1.4 mH (series)
Re = 1.59 ohms (series)
BL = 17.6 N/A
12" Model D2 Coils:
Qts = 0.44
Qms = 9.36
Qes = 0.46
Fs = 41 Hz
VAS = 11.7 L
Le = 3.0 mH (series)
Re = 2.92 ohms (series)
BL = 22.8 N/A
15" Model D1 Coils:
Qts = 0.48
Qms = 9.33
Qes = 0.51
Fs = 40 Hz
Vas = 36.7 L
Le = 1.36 (series)
Re = 1.44 ohms (series)
BL = 15.27 N/A
15" Model D2 Coils:
Qts = 0.44
Qms = 8.64
Qes = 0.47
Fs = 38 Hz
Vas = 36.7 L
BL = 22.8 N/A
I'm kind of scared to ask...but how much do they weigh?
I am assuming the cut dia and outer dia is the same as every other 12 spoke aluminum basket on the market?
Shipping weight is around 60 pounds. The driver being around 55 of that.
Cut-Out is the same as other 12-spoke drivers.
are these subs meant for spl or LSQ?
I wouldn't say either of those really describes it... more like an SPL sub that sounds decent daily as loudcav suggested.
wats the cone area (sd) size of the 15
and the 1 way xmax...if possible do u know wat the peak to peak xmax is...im dying to know
80
Curious, when can (if) we expect the 18" version?
Gonna be a bit - at least for full production.
80
Sd = 810 cm^2
Linear x-max by overhang is 16mm, by 70% BL is around 20 mm - and raw throw is pretty well to basket limits.
Ahh crap. My build may have to wait alot longer lol
Do you have the exact dimensions for cut out and outer dia ???
Cut out for the chrome basket 15" is 13 13/16". Black basket is 13 7/8". For flush mounting the sub I always cut it to 16" for a little clearance. The actual outer diameter is 15 5/8". The mounting depth is 9 3/4".
