sundownz
SPECIAL SD-1 v.2 OFFER
The SD-1 v.2 10" subwoofer is going on sale! Fantastic dual 4-ohm voice coil USA made driver.
MSRP is $229 on these drivers but for the duration of this sale they are available for $150 shipped in the continental 48 states! You won't be able to find another fully USA manufactured driver that is as shallow and performs as well for near that price.
Two of these would work nicely with an SAX-100.2 bridged at 4 ohms or an SAE-1000D running at 1 ohm!
Paypal me at sundownz@sundownaudio.com to take advantage of this offer or go to the easy ordering Paypal checkout:
http://www.sundownaudio.com/SD-1_v2_Sale.html
If you want 4 or more woofers see the following:
4x SD-1 v.2 - $560 shipped
6x SD-1 v.2 - $810 shipped
8x SD-1 v.2 - $1040 shipped
The duration of this sale is not yet determined, so act now while you can to get your hands on some of these drivers!
If you originally pre-ordered some of these and want more please contact me via e-mail and I will credit you $25 for each one that you pre-ordered towards you order since this price is lower than the pre-sale pricing!
DESCRIPTION:
These subs will throw down in very small enclosures and will now handle much more power than the original SD-1. Ideal for shallow truck enclosures! They utilize a single 6" diameter magnet slug to achieve the necessary flux. Behind the cone you will find a progressive roll spider and a special treatment applied to the back of surround and upper lip of the cone to get more stability from the surround and to bring the Mms to where it needed to be. The leads are offset out to the sides and slightly raised to eliminate the possibility for slapping and the motor itself has quite a bit of clearance for the coil thanks to a deeply bumped back plate.
These are serious SQ subs in a very shallow and efficient package. Made the in the USA to the highest possible standards to last for many years to come. They come with our 2-year standard limited warranty against defects. They also carry our 5-year discounted replacement policy -- should you be at fault for damage to your speaker you can purchase a new one at a discount if you send back the damaged one.
SPECIFICATIONS:
Dual 4-ohm impedance
2.5" diameter voice coil
Kapton voice coil former
400-watts RMS rated power
12mm linear excursion one-way
4.5" mounting depth
Narrow profile foam surround for low Mms and maximum cone area
High quality polypropylene cone and dust cap
MADE IN USA
Qes = 0.437
Qms = 4.545
Qts = 0.399
Fs = 28.77 Hz
VAS = 56.92 L
Mms = 88 grams
Cms = 337 uM/N
RE = 7.31 ohms (series)
BL = 16.55 N/A (series)
Le = 2.13 mH (series)
Closing this thread... starting new one.
This model will be discontinued and blown out with limited warranty.
