sundownz
SAZ-3500D Power Testing
This is the "official" post to be linked in our sticky amp power testing post :
This testing done on my Extech True Power meter a full 6-10 seconds in to the burp so we are not catching peak values:
http://www.extech.com/instrument/products/...399/380976.html
HIGH VOLTAGE TESTING:
6x Powermaster D1000s used for testing
17.9 volts rest - did not measure voltage drop.
10,320 watts from the pair @ 1.5 ohms each after rise starting at 0.5 DCR
5160 each
11,470 watts from the pair @ 1.3 ohms each after rise starting at 0.5 DCR
5735 per amp
12v SYSTEM TESTING:
Starting battery + 2x Powermaster D3100s used for testing
3980 @ 0.25 rising to 0.65 @ 11.2v (engine on)
2050 @ 1 rising to 2.44 @ 12.2v (engine off)
With a bit more voltage on tap you can easily expect more power.
Thats Awesome :bigclap: :wacky:
5160 each
5735 per amp
12v SYSTEM TESTING:
I will be doing the same 12v system test, but with two NSB-g3100's.
looks awesome man. now when can i borrow one :P
I wanna see 4 of those in the jeep and numbers with 2 Monster 15's or the 2 NSX 15's!!!
Me too :) Whenever Monsters are production we'll see it.
Okay, I have done my SAZ3000D 12volt power test. I would like to say, WOW!!
My nominal ohm load was 0.5 ohms. I did plenty of test but I got the amp to do its power at the proper settings and did 3 test and took the average.
I used 2 x NSB-g3100 to power the amp, Starting voltage 13.2
Test 1
75.1 volts
39.9 amps
2996.5
box rise 1.88
voltage drop 12.2
Test 2
75.1 volts
37.7 amps
2827.5 watts
box rise 1.99
voltage drop 12.1
Test 3
76.0 volts
39.5 amps
3002.0 watts
box rise 1.9
voltage drop 12.1
Average of 3 test
75.4 volts
39.03 amps
2942.86 watts
box rise 1.92 approximately 2 ohms
So 2942.86 watts @ 2ohms @ 12.1 volts
That is some power!!! :fing34:
Edited by Team Man-Up (Ray)
Test 1
75.1 volts
39.9 amps
2996.5
box rise 1.88
voltage drop 12.2
Test 2
75.1 volts
37.7 amps
2827.5 watts
box rise 1.99
voltage drop 12.1
Test 3
76.0 volts
39.5 amps
3002.0 watts
box rise 1.9
voltage drop 12.1
Average of 3 test
75.4 volts
39.03 amps
2942.86 watts
Nice Ray ...
Also when we did the 12v testing in my Explorer it was only at my peak burp frequency, not at box tuning. We would have seen more power at a lower frequency. I might need to do those tests again.
testing looks good.
Edited by jfin1204
sorption?amper?
Testing from the factory indicates 5800 @ 1 ohm resistive @ 2% THD on 18v.
So my testing is actually pretty close to what the factory tested on a test load.
i just want one.... gez to replace my 3000 ha
those are some awesome numbers
