flakko
Amp Pictures and Stats
Changes for 2007:
* Gunmetal heatsink rather than silver
* Ditching the 600, 1000, 4300, 1000DE, 1500DE, TU300C, TU1000C
* Replaced the 3000DE with the 3200DE
* Empty spaces are filled with the Merlin Line
Stereo:
AX-2000
PWR: 600x2@4, 1000x2@2, 2000x1@4
THD: 0.025% at rated 4 ohms
Damping Factor: >1000
DIM (LxWxH): 27.5 x 11 x 2.7
Multichannel:
AX-5600
PWR: 75x4@4, 90x4@2 + 500x@1 (Sub)
Damping Factor: >200
DIM (LxWxH): 19.6 x 11 x 2.7
Class DE:
AX-600DE
PWR: 250x1@4, 400x1@2, 600x1@1
THD: 0.1% at rated 4 ohms
Damping Factor: >250
DIM (LxWxH): 9.1 x 11 x 2.7
AX-3200DE
PWR: 1200x1@4, 2000x1@2, 3000x1@1
Tubes:
AX-TU600C
PWR: 165x2@4, 300x2@2, 600x1@4
THD: 0.05% at rated 4 ohms
Damping Factor: >600
DIM (LxWxH): 16.1 x 11 x 2.7
AX-TU4360C
PWR: 70x4@4, 90x4@2, 180x2@4
The NEW redesigned Merlin line for 2007:
Changes include:
- Return of the Old School Heat sink
- Completely redesigned internals
- Introducing the MD21 and MD43 and scrapping the MD23
- The subwoofer amps are now strappable and MLT capable
- The Merlins = the AX line
Stereo:
MD21
PWR: 75x2@4, 100x2@2, 200x1@4
THD: 0.03% at rated 4 ohms
Fuse Rating: 30x1
Voltage Range: 12v-16v
DIM (WxHxD): 7.9 x 2.5 x 8.75
Multichannel:
MD42
PWR: 75x4@4, 90x4@2, 180x2@4
Damping Factor: 400
Fuse Rating: 30x3
DIM (WxHxD): ?? x 2.5 x 8.75
MD43
PWR: 100x4@4, 150x4@2, 300x2@4
Damping Factor: 400
Fuse Rating: 30x3
DIM (WxHxD): 20 x 2.5 x 8.75
Monoblock:
MD1d
PWR: 400x1@4, 750x1@2, 1200x1@1 (@ 14.4v)
THD: 0.09% at rated 4 ohms
Damping Factor: 100
Fuse Rating: 30x3
DIM (WxHxD): 12.6 x 2.5 x 8.75
MD2d
PWR: 550x1@4, 1000x1@2, 1500x1@1 (@ 14.4v) <---we all know this is underrated :P
Damping Factor: 100
Fuse Rating: 40x3
DIM (WxHxD): 16.5 x 2.5 x 8.75
MD3d
PWR: 650x1@4, 1200x1@2, 2000x1@1 (@ 14.4v) <---we all know this is underrated :P
Damping Factor: 100
Fuse Rating: 40x6
**note: seeing i have a couple merlins sitting right next to me, and after measuring them i came to the conclusion the manual's dimensions are bunk...i marked down the measurements i know for sure**
Changes for 2007:
* Beefing up the 2000D and the 4000D
Stereo:
XT-800.2
PWR: 75x2@4, 150x2@2, 300x1@4
THD: 0.03% at rated
S/N (@4): 100 dB
Channel Separation (@4): 58
Damping Factor (@4): 250
DIM (LxWxH): 7.9 x 8.75 x 2.5
XT-1600.2
PWR: 125x2@4, 200x2@2, 6-800x1@4
THD: 0.03% at rated
S/N (@4): 100 dB
Channel Separation (@4): 55
DIM (LxWxH): 12.6 x 8.75 x 2.5
Multichanel
XT-800.4
PWR: 50x4@4, 90x4@2, 260x2@4
THD: 0.03% at rated
S/N (@4): 100 dB
XT-1600.4
PWR: 125x4@4, 180x4@2, 400x2@4
THD: 0.03% at rated
S/N (@4): 95 dB
Channel Separation (@4): 50
DIM (LxWxH): 16.5 x 8.75 x 2.5
Monoblock
XT-2000D
PWR: 150x1@4, 300x1@2, 800x1@1
THD: 0.1% at rated
S/N (@4): 80 dB
Damping Factor (@4): 95
XT-4000D
PWR: 200x1@4, 450x1@2, 1200x1@1
THD: 0.1% at rated
S/N (@4): 80 dB
**Discontinued AX amps:**
AX-600
AX-1000
PWR: 300x2@4, 500x2@2, 1000x1@4
AX-4300
AX-1000
PWR: 350x1@4, 700x1@2, 1000x1@1
AX-1500DE
PWR: 500x1@4, 900x1@2, 1500x1@1
AX-TU300C
PWR: 100x2@4, 160x2@2, 320x1@4
DIM (LxWxH): 13.6 x 11 x 2.7
AX-TU1000C
**Discontinued. Replaced with a redesigned Merlin Line**
for reference:
MD22
Power: 165wx2 @ 4 310wx2 @ 2 650wx1 @ 4
S/N Ratio: 103dB
THD: >.03%
Freq Response: 10hz-30khz
Channel Separation: 90dB
Damping Factor (@14.4v): 500
Crossover: HP 65hz-1khz LP 40hz-250khz Subsonic: 15-40hz
Protection: thermal, overload, short circuit, dc off-set
Fuse Rating: 25A x 3
Size (WxHxL): 2.4" x 9.0" x 18.9"
MD23
Power: 300wx2 @ 4 460wx2 @ 2 960wx1 @ 4
S/N Ratio: 105dB
THD: >.03%
Channel Separation: 95dB
Damping Factor (@14.4v): 600
Fuse Rating: 30A x 3
Size (WxHxL): 2.4" x 9.0" x 20.0"
MD41
Power: 50wx4 @ 4 80wx4 @ 2 180wx2 @ 4
S/N Ratio: 100dB
THD: >.03%
Channel Separation: 85dB
Damping Factor (@14.4v): 400
Fuse Rating: 25A x 2
Size (WxHxL): 2.4" x 9.0" x 16.5"
**note about the amp ratings, some if not of these amps are underrated, by how much...i dunno, your gonna have to bench them to find out hehe :). But i know the MD2 benched at like 1950w @ 1 and the IS 4085, dirk said can do 100x4, not the rated 85x4**
**Discontinued. Replaced with Xterminator Line**
for reference:
IS2080
Power: 80wx2 @ 4 135wx2 @ 2 270wx1 @ 4
S/N Ratio: 101dB
THD: >.01%
Channel Separation: 51dB
Damping Factor (@14.4v): 95
Crossover: HP 65hz-4.5khz LP 40hz-460khz
Protection: Reverse Polarity, Thermal, Short Circuit
Fuse Rating: 30A
Size (LxWxH): 11 x 9.5 x 2.5
IS2100
Power: 100wx2 @ 4 165wx2 @ 2 330wx1 @ 4
S/N Ratio: 103dB
THD: >.01%
Channel Separation: 52dB
Damping Factor (@14.4v): 110
Fuse Rating: 20Ax2
IS2150
Power: 150wx2 @ 4 250wx2 @ 2 500wx1 @ 4
S/N Ratio: 105dB
THD: >.01%
Damping Factor (@14.4v): 150
Crossover: HP None LP 40hz-460khz
Fuse Rating: 30Ax2
Size (LxWxH): 14.5 x 9.5 x 2.5
IS2200 (prefrebly used for subwoofers)
Power: 200wx2 @ 4 340wx2 @ 2 680wx1 @ 4
S/N Ratio: 101dB
THD: >.01%
Channel Separation: 62dB
Fuse Rating: 40Ax2
Size (LxWxH): 16.1 x 9.5 x 2.5
IS4065
Power: 65wx4 @ 4 115wx4 @ 2 230wx2 @ 4
S/N Ratio: 100dB
THD: >.01%
Channel Separation: 45dB
Damping Factor (@14.4v): 90
Crossover: HP 12hz-200khz LP 40hz-200khz
Fuse Rating: 20Ax2
Size (LxWxH): 11.8 x 9.5 x 2.5
IS4085
Power: 85wx4 @ 4 135wx4 @ 2 270wx2 @ 4
S/N Ratio: 101dB
THD: >.01%
Fuse Rating: 30Ax2
