sundownz
SAZ-1500D High Voltage Testing
Here's the setup, a pair of Sundown Audio SAZ-1500d's strapped at 1 ohm.
In the box used in the test (a single Funkin Audio MF12, dual 2), rise went from 1 ohm to 2 ohms during play. Here are the results:
Notes:
* Highest power on 16.0v rest was 4663 watts on 14.3v
* Highest power on 16.5v rest was 5136 watts on 14.3v
* Highest power on 17.9v rest was 5677 watts on 15.5v
* 84% efficient on 15.0v and 180 amps of draw per amp
There was a 10% increase in power starting 0.5v higher with an ending voltage being the same. There was another 10% increase when starting at 1.4v higher and ending 1.2v higher. This would tell me that a lowest voltage over 16.5v likely wouldn't be much of a gain from below that.
No matter how ya look at it, tapping the 5700 mark on 15v isn't too shabby from a pair of 1500 watt amps.
Can these results be divided by 2 to get the single amp rating at these voltages? I know in theory they can...but things rarely work out like that.
Do you have single 1500d at various voltage/impediance numbers?
Dividing by two works fine. We have not tested them un-strapped at high voltage specifically.
so does this mean it gives out over 4500 watts at 2ohm at 14.3 volts
