EPerez
SSA Regular
    2,847
  • Days Won
    10
Everything posted by EPerez
  1. EPerez
    amp suggestion
    1000 rms, are you buying the q's or bl's? Well get 2 D1s (1 ohm dvc) if you want to run them at 1 or 4 ohms or get 2 D2s (2 ohm dvc) if you want to run them at .5 or 2 ohms. I suggest getting 2 D1s and running at 1 ohm on amp.
  2. EPerez
    amp suggestion
    I have a crescendo bc2k and I got it new for 339.00 from crescendo. I love it and like the aq2200 it has the clipping indicator on the bass knob so that's a plus!
  3. If you plan on running more power in the future you should upgrade. Just incase you haven't completed the "big 3" I would highly recommend doing that.
  4. I'll do a build log once I get the sub! I saw your thread, 14k, about your 4 15s. That's gonna be loud
  5. I just sold my hdc3 15 and Im wanting to upgrade to either a zcon 18 or warden 21.I would be buying the zcon brand new or the warden used for around the same price. I just dont know if a warden sounds good on music. This is going in a 03 trailblazer. I have a crescendon bc2000 for now to use. If i get the warden then ill have to run it at .5 ohms because its a D1. Im going to buy a xs d3100 to add to my deka 9a31 if i go that route so my electrical will be good. So I just need to know if the warden will be good for daily? If you need more info please ask. Thanks!
  6. I decided to go with the warden!
  7. how much is the warranty?
  8. If you got the electrical it'll be fine, you can buy a 2 yr .5 ohm warranty from crescendo so I don't think it would hurt it. As of the BC line, Crescendo doesn't warrant below 1ohm. I thought you could buy a warranty?
  9. Current draw will increase dramatically when switching from 1 to 0.5, just something to keep in mind. That's why I plan to buy another battery to help keep the voltage up.
  10. I know that about cone area. I'm asking because in most set ups I see, theyre use for comps. Im not competing so i didnt know how good itll be on music. I dont go below 14v as it is right now with one deka 9a31.
  11. EPerez
    How to build a wall
    I've been looking at peoples builds that involve walls. My question is could you just build a box and stand it up to facing forward then seal it off? How come you have to secure the box so much when its walled but when you have it laying normal it doesn't have to be?
  12. EPerez
    plasti-dip Fing madness!! and a little treat haha
    Even better lol how far should i spray for best results?
  13. EPerez
    Ohh cause I want to do my rims and I didn't know how much I would really need. I'll probably buy 3 or 4 cans.
  14. EPerez
    Did you use up all 3 cans or did you have some left?
  15. EPerez
    How to build a wall
    I would definitely secure it down though! I just dont want to drill the whole wall to the frame.
  16. EPerez
    How to build a wall
    See I don't want to do that, I just wanted to do 2 xcon 18s off around 2500 rms.
  17. EPerez
    How to build a wall
    Depending on your car yes you can, larger vehicles you can build it outside of the car and place it in and finish it. but it MUST be secured down. Ok because I have a trailblazer and I was thinking about it with 2 18s so I guess that's a possible option for me. Thank you.
  18. EPerez
    How to build a wall
    I didn't mean for it to be it shouldnt lol but as much. Couldn't I just take a box stand it up and face it forward though and just seal it off or is it a whole different way you have to set it up for having it walled?
  19. EPerez
    new subs?
    Well the xcon is two steps up from the dcon. Ssa also told me it would be ok running 1k to an xcon even though it states 1750 rms. 1k would get it moving.
  20. EPerez
    new subs?
    I agree with deyoung, get the xcon. All of ssa products are top quality.
  21. EPerez
    new subs?
    All I heard was good things about ssa. I'm thinking about getting a zcon. Ive heard an l7 and I just don't like the way it sounds and I've also heard my friends 15 bl and it sounded pretty good and got decently loud
  22. EPerez
    Box design for Zcon 18
    The vehicle will flex around the woofers. Which will mess your lows up. So you mean deadening the truck? If so I currently do not have any but I will soon.
  23. Well I think Im goin to go with a Zcon 18 for my trailblazer. I have enough room for the 18 but what would be best for the box size and tuning. I know 6 to 8 cubes is optimal with 31-37hz tuning but what have you done or do you think is the best? Also how should I have the sub and port face? I'm pretty sure sub up port back. For amp and electrical, I have a crescendo BC2k and a deka 9a31 in the back. I'm not going for numbers, just straight daily. I listen to mostly rap and that's what I want it to sound best with. My max dimensions are 46w x 32.5d x 20h. thanks in advanced and if you need anymore info please ask.
