mwerling1212
Members
    232
Everything posted by mwerling1212
  1. mwerling1212
    RCA grounding
    try this http://www.icixsound.com/vb/showthread.php?t=40067 the problem is the rca output needs to be grounded not the rcas ... im pretty sure there is a difference ... i did this in my car and it worked ... it didnt get rid of all the noise but most Thanks. ill try that and see if that helps.
  2. mwerling1212
    RCA grounding
    Yea its a pioneer. Everyone said that all i gadd to do was ground the rcas, but i tried that and it didnt work. I might be doing it wrong though.
  3. mwerling1212
    RCA grounding
    yea i tried to redo the negative battery ground, but the stock location is terrible. Could i just sand a spot on the metal, then take some 1/0 with a ring terminal on the end, then just solder it to the metal? because i dont know how else to do it. thanks.
  4. mwerling1212
    RCA grounding
    Yes. i redid both grounds. Could it be the battery ground? because it is still the stock ground and i cant get it off.
  5. I also have the same problem with my pioneer hu. Its really making me angry right now because i cant get rid of the buzzing, and i dont have enough money to get a new hu.
  6. mwerling1212
    loud screeching noise
    thanks man. im diggin the eclipse head units anyways. lol
  7. mwerling1212
    could it be the hu ground thats not properly grounded? because its only bolted a little metal plate under the hu.
  8. mwerling1212
    Im bringing this one back up because i have the exact same problem. can someone please explain how to ground my rcas?
  9. mwerling1212
    Trying to solder
    i couldnt seem to get the solder to melt to the ring terminals when i first tried soldering. someone told me that you just have to hold the soldering iron on the 1/0, then let the solder melt into the 1/0, and that worked for me. I torched some of mine also. you just have to be careful you dont burn the jacket when you torch it. the torch will also melt the solder immediately, so make sure you put the solder on the 1/0 first. i figured that out the hard way and burnt myself. lol.
  10. mwerling1212
    Trying to solder
    get a torch. i bought a weller 100 watt soldering iron for 20 bucks and it took way to long to melt the solder and "soak" in. torches work better i think.
  11. mwerling1212
    port placement
    Thanks for the help. I think im going to try sub up, port back. i just have a good week or so now before i get my new amp, so i have a lot of time to prepare!
  12. mwerling1212
    port placement
    I have a 1990 lincoln towncar, and i need help deciding on where the sub and port should go. I had my ss rl-p18 in there, sub/port back, but i didnt like that. I cant put the sub forward because ltc trunks are like pits with no clear passage to the cab if you get what im saying. Thanks
  13. mwerling1212
    port placement
    bump.
  14. mwerling1212
    port placement
    need some input today, im buying the wood later!
  15. mwerling1212
    need help finding a video
    i found a video of 4 18's in an expedition if that helps.
  16. mwerling1212
    port placement
    I cant really see the port, but if its facing forward into the cabin, i cant do that because of how the ltc trunks are.
  17. mwerling1212
    new box!!!
    So i think im just going to make it about 6 cubes, and tune to 28hz. Im also trying to get an saz1000d or something that puts out 1000 watts at 1 ohm, so that might help a little with the output. Any other input on the size and woofer/port placement?
  18. mwerling1212
    new box!!!
    I started to notice my sub was sounding a little weird today, so i check my box to make sure everything was ok, but it wasnt! i must have a leak in my trunk seal, because my box was soaked with water. booo. but anyways, i will be building a new box after i fix the leaks, and i need some advice on a different box setup. MY box was about 5 cubes after sub and brace displacement, tuned to 27hz. (sub/port back). I wasnt really impressed with the output at lower frequencies, and the overall output from the setup. (ss rl-p 18, aq2200d) Can anyone suggest a different design that can maximize the overall output? It's in a 1990 lincoln towncar. Thanks!
  19. mwerling1212
    blown tweeter
    well i got a little happy with my volume knob today, and blew my driver side tweeter. i admit it was my fault. but anyway, i cant find any tweets for sale, so i was wondering if i could buy a different set for the mids. They are polk momo 6.5's. any cheap tweeters you could suggest? thanks!
  20. mwerling1212
    new box!!!
    well ido listen to A LOT of chopped and screwed/ slowed down music. Some of it drops down to 24 hz, and i want to it to slam harder on those notes.
  21. mwerling1212
    new box!!!
    I cant really face it into the car because it's a towncar. the lowpass is at about 80, and its wired to 4 ohms getting about 740 watts. i heard that a bigger box would help out the lows.
  22. mwerling1212
    new box!!!
    bump. i want to start today on the box, any more input?
  23. mwerling1212
    new box!!!
    i was thinking of making the box sub up, port back, at about 6.5 cubes tuned to 28hz. does that sound ok?
  24. mwerling1212
    new box!!!
    i have the ssf at about 25. Should i build a bigger box? i have enough room for about 7 cubes.
  25. can i ground my amp to another ground in the trunk? ill have a picture in a moment when i figure out how.
