All Activity
This stream auto-updates
  1. Earlier
  2. ihop check in.
  3. Checking in.
  4. That’s a great explanation and really helps people understand the difference between how pro audio speakers and regular coaxial ones perform. I’ve used PRV speakers myself, and tuning them right makes a big difference. You are absolutely right about not pushing them to play outside their natural range because it keeps the sound much cleaner. I’ve been testing a few setups lately, including some and the same principle applies there too. When you match the right crossover points and balance your midbass and mids properly, the sound becomes more natural and powerful without distortion. I would definitely like to see that in-depth write-up you mentioned since it would help a lot of people who are trying to build a balanced sound system.
  5. First, check how much power your amplifier gives per channel at 4 ohms because that tells you how much power each speaker will get. If your amp is 300 watts total, it’s probably giving around 150 watts per channel. When you connect two speakers to one channel, each one will get about half of that power, around 75 watts each. So you should look for speakers rated close to that, around 75 to 100 watts RMS, so they can handle the power safely without distortion. If you’re not sure how the speakers are wired, remember that wiring them in parallel will lower the resistance and draw more power, while wiring them in series will raise it and reduce power. For the best sound and safety, try to match the speaker power handling to what each channel of your amp can provide.
  6. Evening fam
  7. Welcome, looking forward to build pictures.
  8. Im new to the group and just wanted to introduce myself. My name is Christian I live in Greenfield Massachusetts, I work as an extrusion operator at Mativ International and go to school at Full Sail University for Audio Production. I am currently building my fiancés car with a SSA Zcon. Hope you guys have a great day. Thanks, Christian
  9. Chrismora91 joined the community
  10. Checking in!
  11. ihop is still here.
  12. Also can you take a look at the Optional Profile Information Some of it is VERY dated now
  13. Got it twice ... Also I recommend everyone change their password if they are going to be on here again. Google recommends it
  14. Just curious if you guys got the newsletter about the forum upgrade.
  15. Just curious, how everyone who has one, is liking theirs.
  16. How did this turn out?
  17. Finally had some time to mess with the software and the lack of function the previous version had. Sorry for the delays.
  18. Jaysr420 joined the community
  19. Bcakes joined the community
  20. musgofasa changed their profile photo
  21. kennedyscott_ joined the community
  22. Yzbiker89 joined the community
  23. More pictures of everything done. The center channel sits right below the TV.
  24. They are a pro audio company that has been around for decades. The 6174 was one of the first true pro audio subwoofers. Once the Aura Sound NRT came on the scene, it sort of dethroned the 6174, but more in sheer output. I don't know of too many other drivers available to this day that are as efficiency as a 6174 on the last octave, if enclosure size isn't a concern.
