All Activity
This stream auto-updates
  1. Yesterday
  2. Don't know if this goes here or not but when I click on the SSA Products tab (any of the options: Subwoofers, Speakers, Amps, or Electronics) at the top of the webpage it gives me an Internal Server Error. It's been like that for well over a year. Can this be fixed? I liked looking at all the info on the SSA products and discontinued gear and it helped when researching specs for older models.
  3. Earlier
  4. ihop check in.
  5. That’s a great explanation and really helps people understand the difference between how pro audio speakers and regular coaxial ones perform. I’ve used PRV speakers myself, and tuning them right makes a big difference. You are absolutely right about not pushing them to play outside their natural range because it keeps the sound much cleaner. I’ve been testing a few setups lately, including some and the same principle applies there too. When you match the right crossover points and balance your midbass and mids properly, the sound becomes more natural and powerful without distortion. I would definitely like to see that in-depth write-up you mentioned since it would help a lot of people who are trying to build a balanced sound system.
  6. First, check how much power your amplifier gives per channel at 4 ohms because that tells you how much power each speaker will get. If your amp is 300 watts total, it’s probably giving around 150 watts per channel. When you connect two speakers to one channel, each one will get about half of that power, around 75 watts each. So you should look for speakers rated close to that, around 75 to 100 watts RMS, so they can handle the power safely without distortion. If you’re not sure how the speakers are wired, remember that wiring them in parallel will lower the resistance and draw more power, while wiring them in series will raise it and reduce power. For the best sound and safety, try to match the speaker power handling to what each channel of your amp can provide.
  7. Evening fam
  8. Welcome, looking forward to build pictures.
  9. Im new to the group and just wanted to introduce myself. My name is Christian I live in Greenfield Massachusetts, I work as an extrusion operator at Mativ International and go to school at Full Sail University for Audio Production. I am currently building my fiancés car with a SSA Zcon. Hope you guys have a great day. Thanks, Christian
  10. Chrismora91 joined the community
  11. Checking in!
  12. ihop is still here.
  13. Also can you take a look at the Optional Profile Information Some of it is VERY dated now
  14. Got it twice ... Also I recommend everyone change their password if they are going to be on here again. Google recommends it
  15. Just curious if you guys got the newsletter about the forum upgrade.
  16. How did this turn out?
  17. Finally had some time to mess with the software and the lack of function the previous version had. Sorry for the delays.
