January 2, 200818 yr Several have tested them in Street -- Ray Farmer on Team Sundown was seeing ~7600 from his pair on a DD Battery. He posts on the forum so perhaps he can chime in with more details for you.
January 3, 200818 yr Hell ya,I consistantly got 7400+ watts, with the maxx-link. Without the maxx-link it was above 6000 watts per strapped pair. So the maxx link gives a stronger signal to the amps. Now I must remind you, this is with a street A setup and a strong battery with the car completely shut off. Ray
January 3, 200818 yr Jacob, what can the SAZ series take as far as input voltage? If the Maxxlink puts out a stronger signal, what is the RCA range?
January 3, 200818 yr Author Hell ya,I consistantly got 7400+ watts, with the maxx-link. Without the maxx-link it was above 6000 watts per strapped pair. So the maxx link gives a stronger signal to the amps. Now I must remind you, this is with a street A setup and a strong battery with the car completely shut off. RayWhat voicecoil configuration do you use, I will be using four 3000ds in Street-Max 1-2.
January 3, 200818 yr Jacob, what can the SAZ series take as far as input voltage? If the Maxxlink puts out a stronger signal, what is the RCA range?They are rated for 6 volts input.One of the other features of the Maxx-Link is that it straps the amps differently so the slave amp is less likely to go into protection under a full out SPL burp.
January 3, 200818 yr Jacob, what can the SAZ series take as far as input voltage? If the Maxxlink puts out a stronger signal, what is the RCA range?They are rated for 6 volts input.One of the other features of the Maxx-Link is that it straps the amps differently so the slave amp is less likely to go into protection under a full out SPL burp.I use dual ones, and strap a pair of tens to one ohm so each amp sees 0.5 ohms. You may be able to strapp lower than 0.5ohms if you are burping with a power above 12 volts or if the car is running. But that question is more suited for Jacob. Secondly what the maxx-link does is reverse phase the slave amp so it runns as a master amp. So you strapp the amps as you normally do with out using the link cable. This enables the amps to run at a stronger signal. And also the maxxlink is some what of a pre-amp. It allows you to raise the input RCA voltage. Example. head unit gives off 2volt you can adjust the maxxlink so the amps can receive 5 or 6 volts.Ray
January 4, 200818 yr Hell ya,I consistantly got 7400+ watts, with the maxx-link. Without the maxx-link it was above 6000 watts per strapped pair. So the maxx link gives a stronger signal to the amps. Now I must remind you, this is with a street A setup and a strong battery with the car completely shut off. RayWhat voicecoil configuration do you use, I will be using four 3000ds in Street-Max 1-2.I will be running 4 in my StreetMax 1-2 vehicle also.
January 4, 200818 yr ray... your the man.... big jon from texas ...... got the hifonics for you...Thanks Big Jon. Hey, I hope you are jumping on the SAZ-3000D Band Wagon!?!?Ray
January 4, 200818 yr Author I'm hoping to have the whole set-up up and running for SBN at the end of march.
