Just got em back from the machine shop - had to get the holes tapped for basket bolts.
I talked to the machine shop about making an optional heat plate as well... would bolt between the basket and top plate. May be an option on these :)
  • Replies 81
  • Views 12.7k
These will be one line up from the Nightshades - rated for 2250 - 2500 watts RMS.
nvm.... pics just showed an x.... then I posted and now they load... hmmm.
Edited by rushnrun
15" Baskets.
The motors are not especially large - but I am expecting great results ;)
15" Baskets.
As always Jacob, we are expecting great things from this sub, will it be offered in the 18" size too?
And are you going for more efficiency than the nightshade with this as well?
I'll leave you get back to work now ;p
Should have much more motor force than the Nightshade - better for SPL scores.
15" Baskets.
they still look large enough to do some serious damage :)
very nice....more power then the nightshade but less power then the monsters......
i cant wait to see your testing of these... i just may be looking at my new subs:D
edit: if they will work in 3 cubes!
Put a 12" basket on that and I will be glad to test yout theory :wacky:
We may do that - we'll see how everything works out!
These are higher than the Nightshade - so more than Z15 and Nightshade.
a ok...
aesthetically appear below Nightshade. :D
But are designed specifically for the spl?
Nightshade then to play music every day
while this new model for spl
Yes, the Nightshade is still going to be better for a smooth daily response -- these have much higher motor force and power handling than the Nightshade so will be superior for SPL applications.
These can still be used daily but are a bit more towards the SPL side than the Nightshade.
Don't be fooled by the smaller physical dimensions... these are only about 2 pounds lighter than the Nightshade motor and pack more motor force :)
ok.
expect photos of the engine, compared to the engine near the traditional Nightshade
the diameter of the magnets is the same?
you have other photos?
and the monster?
Monster is higher than these even :)
I'll get more photos later when they are built.
ok, last question
sound at low frequencies should be greater the classic Nightshade?
reproduces the low frequencies the most classic Nightshade?or this?
ok, last question
Classic Nightshade should have smoother low frequency extension in an equal enclosure. The Nightshade-X will give louder peak SPL, though.
wow every time i go to sundown section there always something new coming out! wow! when that other bad boy sub coming?
