Posted February 28, 200917 yr ok so one night i was sitting around thinking up some new box ideas. i really want to have my sub facing forward into the cab of my car, and have the port be on top of the subwoofer. so i was doing some concepting and came up with this, Box idea. I just want to know if it will work.i forgot to put notes so....notes:1. double baffle front plate2. round port edges3. 2.8 ^3 feet of airspace after all displacement4. 3/4" mdf or particle board used.its going to be firing forward with the trunk sealed from the cabin.thanks,Anton Miller
February 28, 200917 yr ok so one night i was sitting around thinking up some new box ideas. i really want to have my sub facing forward into the cab of my car, and have the port be on top of the subwoofer. so i was doing some concepting and came up with this, Box idea. I just want to know if it will work.i forgot to put notes so....notes:1. double baffle front plate2. round port edges3. 2.8 ^3 feet of airspace after all displacement4. 3/4" mdf or particle board used.its going to be firing forward with the trunk sealed from the cabin.thanks,Anton MillerI like I would try to make the port alittle longer though..... But thats just me
March 1, 200917 yr So the port comes up the inside of the box then rotates 90 degrees and fires out the front? I don't know that you'd want to do that because your port may act differently than you predict. But I guess you can try it.
March 1, 200917 yr Author yea im not sure how well it would work but i thought i would draw it up and then see what people said before i start building. any more help would be appreciated.
