ok so I have used a few different calculators and got different lengths...
the box is gunna be 4.0ft^3 for a 15" Q tuned to 32 HZ
on carstereo.com calculator i got H 6"xW 10"xL 28"
on winisd pro i got 6x10x 32.9 L??
what one should I got with or are there any other calculators I should look at?
also what would my port area be looking at and would I be in the recommended 12-16" range?
Thank for any help
-Ryan
same here man, i just dont get it different programs give u different porth length, hopefully scott or somebody that knows this can help us.
Length would depend on if its a free standing port, or using 1 or more sides of the enclosure. If for some reason the 6X10 port uses 3 sides of the enclosure, then about 29" would be correct. If its free standing then 32 and change would be. Im not sure if some of these programs take end correction into account or not... WinISD seems OK for most of its recommendations and I tweak from there slightly depending on port orientation.
