hello everyone, can someone tell me how to tune a subwoofer box or knows of a good online calculator thats is acurate??? i need a box for two fi bl15' s i got 43 inches wide and 18h to play with in my trunk. i have a rockford fosgate t215 sitting here next to me now. before a met my fibl15 i thougt t215 was the best sub out there on the market, very well desinged but after putting my fibl15 in the same box same amp i was like wow it gets louder than my t2 so im getting another bl15 and I AM A sell the rockford, to be hones i never tought the bl15 would sound better than my t2 since it weighted a lot less was a lot smaller i really was disaponted when i saw my fi its nothing compare to my t2 but after i tryed it i liked it and im keeping it, buying another one like it and selling my t2 great sub fi. now i just need a good calculator to make my box, whats a good tunning frequency for bl15?? i listen mostly rap so lots of bass please help. :ready2go:
Edited by caddyon20s
  • Replies 87
  • Views 12.3k
please help i need a two chamber box, that is becuase i have two amps
OOOPS sorry man but i suck at math, can somebody desing a box for me please, i need 4cu ft per chamber and both sides tuned at 35hz the box needs to have a divider in the center for two separate boxes for my subs, my demensions are 43"W 18"H and i can lots deep five dollars will be given to the desinger of my box, i can pay trough paypal or just send u the money in an envelope thanks.
please send the desing to my email adress [email protected] after uve sent me the desing i will pay.
http://i209.photobucket.com/albums/bb247/c...pg?t=1186348758
l_ef78bbe9a49bfca20a47ef2f00066142.jpg my bros car
l_e4903d5c6a4c8aca62add6b36f758c40.jpg thanks to my self for all the hard work i did today l_816a5514d957d0f6530e63a4cf5b82df.jpg please no haters thank you.
Looks to be 1/2" particle board, and the port doesn't have an opening inside the box that is big enough...
Almost TCAB worthy.
well i got it from home depot i think total was 44 dollars, 3/4 a pain in the a?s to get it home since i dont have a truck, some of my friend do but i didnt wanna ask since they have nice trucks they probably woundnt want their truck scratched, so i used my sis explorer the one on the above pic they berley fit inside the truck, thebox is 42.5"W x 18"H x 26"D the vent is 3"w and 16.5" H the port length is 22.5 hopefully it will sound good.
box is 3.70 cu ft per chamber aftert port and subwoofer displacement total box gross =9.59 cu ft
2nd to the last pic look sto be regualr Particle wood to me... MDF is much finer and looks much smoother...
i still need to get the carpet but its almost done, I AM A be running two bl15 and two p8002 rockford amps cant wait to try it out.
please post your coments
Did you even read your own thread? You used the wrong wood. That box doesn't have a chance.
And jesus christ.. tell your friends to grow some balls. Its a truck. Its supposed to get fucked up.
And jesus christ.. tell your friends to grow some balls. Its a truck. Its supposed to get fudgeed up.
Wrong wood is debatable. As long as the cuts were good and it is secured at the joints correctly for a good seal, I highly doubt much difference can be heard between MDF and small particle board. At least it isn't ugly OSB or something.
Someone said the opening for the port internally wasn't big enough. It looks to me that the opening is just as wide inside as the mouth on the outside. Is there a reason to have it wider than the mouth? Serious question.
Umm, no its not. Regrettably son you have just built a box that will be better suited to start a fire than hold subs. You need to go back and buy MDF.
start a fire, my current box for my t215 is made out of particle board and it pounds the shi* out of my car never had a problem with it and i've had it for more than a year. When ever i get the subs mounted in and everything done I AM A upload a video so everyone can watch it if it doesnt sound good its ok at least i tryed ((((((( :finger: thanks everyone for ur great help on desinging my box :finger: ))))
Well, whenever you want to learn something, we'll be here.
start a fire, my current box for my t215 is made out of particle board and it pounds the shi* out of my car never had a problem with it and i've had it for more than a year. When ever i get the subs mounted in and everything done ima upload a video so everyone can watch it if it doesnt sound good its ok at least i tryed ((((((( :finger: thanks everyone for ur great help on desinging my box :finger: ))))
I wasn't bashing you for trying, but you really should have asked a bit deeper when going into something you don't know how to do. It is great that you tried, and almost succeeded but regrettably particle board is no where near a viable solution for a sub box.
I AM A try it out and if it doesnt work good I AM A switch to mdf wood,, the box building process took me like 6 hours i can spend another 6 making another one, but like i said my current box is made out of particle wood and its sounds really good no problems at all for more than a year.
How much power are you running in your current enclosure ? :)
