Posted August 6, 200719 yr Do you think a Soundstream PCA2000D would give me enough power to push two 15" or 18" Qs? If so would I purchase dual 2 or 1 ohm subs? If I wanted to get the full power out of the amp I would have to go with the 1 ohms, but how would I wire them? This amp is only stable at 1 ohm right? Would a .5 ohm load put too much stress on the amp? Any help would be appreciated. Thanks. Edited August 6, 200719 yr by obriab63
August 6, 200719 yr Do you think a Soundstream PCA2000D would give me enough power to push two 15" or 18" Qs? If so would I purchase dual 2 or 1 ohm subs? If I wanted to get the full power out of the amp I would have to go with the 1 ohms, but how would I wire them? This amp is only stable at 1 ohm right? Would a .5 ohm load put too much stress on the amp? Any help would be appreciated. Thanks.I have the same amp on a pair of Q 12's. It will work just fine. I wouldn't run the amp lower than 1ohm though. A pair of dual 1ohm Q15's would be the way to go.
August 6, 200719 yr Author Do you think a Soundstream PCA2000D would give me enough power to push two 15" or 18" Qs? If so would I purchase dual 2 or 1 ohm subs? If I wanted to get the full power out of the amp I would have to go with the 1 ohms, but how would I wire them? This amp is only stable at 1 ohm right? Would a .5 ohm load put too much stress on the amp? Any help would be appreciated. Thanks.I have the same amp on a pair of Q 12's. It will work just fine. I wouldn't run the amp lower than 1ohm though. A pair of dual 1ohm Q15's would be the way to go.Do I wire them at 1ohm just like you would wire a 4ohm sub?
August 6, 200719 yr 2 D1 subs, wire in series parallel.can i detail a bit ? voice coils in series, then subs in parallel
August 6, 200719 yr Author 2 D1 subs, wire in series parallel.can i detail a bit ? voice coils in series, then subs in parallel Example?
