Posted August 8, 200719 yr I tried to buy 2 Mj-18's from ssa and it said purchase failed. but when i get to my account and then to order history it says 2 mj-18's pending. does that mean theyre in my cart? or purchased?
August 8, 200719 yr Admin that means your order is in the system, but your payment failed. I can cancel your cart order then you can retry your order. Probably something wrong with your credit card info. You could try paypal if you have it as well
August 8, 200719 yr Author that means your order is in the system, but your payment failed. I can cancel your cart order then you can retry your order. Probably something wrong with your credit card info. You could try paypal if you have it as wellthatd be great thanks. i think i got the exp date wrong
August 9, 200718 yr Author that means your order is in the system, but your payment failed. I can cancel your cart order then you can retry your order. Probably something wrong with your credit card info. You could try paypal if you have it as wellthatd be great thanks. i think i got the exp date wrongso if it says pending...then the order didnt go through? because i wasnt using my credit card to do it. i then made a new acct with the name on the card thinking that would do it...and on that accounts order history its said pending for 5 hours...
August 10, 200718 yr Admin that means your order is in the system, but your payment failed. I can cancel your cart order then you can retry your order. Probably something wrong with your credit card info. You could try paypal if you have it as wellthatd be great thanks. i think i got the exp date wrongso if it says pending...then the order didnt go through? because i wasnt using my credit card to do it. i then made a new acct with the name on the card thinking that would do it...and on that accounts order history its said pending for 5 hours...Pending means that the order was placed, but no money was transfered.
August 10, 200718 yr that means your order is in the system, but your payment failed. I can cancel your cart order then you can retry your order. Probably something wrong with your credit card info. You could try paypal if you have it as wellthatd be great thanks. i think i got the exp date wrongso if it says pending...then the order didnt go through? because i wasnt using my credit card to do it. i then made a new acct with the name on the card thinking that would do it...and on that accounts order history its said pending for 5 hours...Pending means that the order was placed, but no money was transfered.I'm having the same problem with mach5audio.com store. i placed an order and it still says pending but i paid through paypal and it took it out of my bank account. any help? mark hasnt replied.
August 10, 200718 yr That means that your order has been placed, but he hasn't gotten to it yet. You will get an email notifying you when he gets it. If it's in stock, then it will go in to the processing stage.In the processing stage he does burn-ins etc and ships it off. Don't worry, just be patient. The reason Mark hasn't got back to you yet is most likely the same reason your order is still pending.Enjoy the subs and keep us posted on your build
August 10, 200718 yr That means that your order has been placed, but he hasn't gotten to it yet. You will get an email notifying you when he gets it. If it's in stock, then it will go in to the processing stage.In the processing stage he does burn-ins etc and ships it off. Don't worry, just be patient. The reason Mark hasn't got back to you yet is most likely the same reason your order is still pending.Enjoy the subs and keep us posted on your build will they sound good in 3.5 cubic foot prefabed box? i think its tuned to high 30s.. and i know the recommended is 28hz..
August 11, 200718 yr my box is 3.8@ 34hz and it sounds good to me but it would sound better in 4.5@30hz
August 11, 200718 yr Author ya i hope my order on SSA was cancelled. I placed on order on Mach5 but now when i go to the My Account part it doesnt recognize my email or password which confuses me a little bit...
