Posted August 22, 200719 yr Just ordered a Havoc 18 to replace my 4 tens. I will try to do some kind of review when I get it, although the only thing I have to compare it to will be my 4 tens. Wish me luck!!!
August 22, 200719 yr good luck man. youll be pleased going to an 18. and just to make you want it some more, mine came in today
August 22, 200719 yr Admin all the build logs reviews will be sweet to add to SSA as content. thanks again for the business guys.
August 22, 200719 yr Author Scot, Is the cone as smooth and sexy as it looked in the original AA pics? Are you going sealed or ported with yours?
August 23, 200719 yr Scot, Is the cone as smooth and sexy as it looked in the original AA pics? Are you going sealed or ported with yours?why yes it is. and i havent built a sealed box in years, and i dont plan to anytime soon.
August 23, 200719 yr Admin Scot, Is the cone as smooth and sexy as it looked in the original AA pics? Are you going sealed or ported with yours?why yes it is. and i havent built a sealed box in years, and i dont plan to anytime soon. I luv those subs!
August 23, 200719 yr id say i have a new sub i want to buy. maybe throw 1500 to it. in a nice low tuned box. 4.0 / 4.2 @ 28 hz anyone? or maybe a 2.0 sealednice sub.
August 23, 200719 yr Author I'm going about 5 sealed, maybe a bit bigger if I have the room.... Must measure stuff!!!
August 27, 200719 yr If you don't post multiple pics and flexing videos, you will be banned nah, just playin. For real, tho. Get some vids!
August 27, 200719 yr wow i havent seen a cone look that good since tc sounds stop using the white conesthats sub can get it80
August 29, 200719 yr Author It's here!!! And sexy as hell. The beast wieghs in at 35 pounds. I'l be starting the build by the weekend, shouldn't take too long as I'm going to use the enclosure I already have, and build on to it. Pics are coming, probably early next week as I dont have a digital cam, using a disposable. My cat loves it too(you'll see what I mean)
September 2, 200719 yr Author Hers my cat lovin on the havoc:http://www.soundsolutionsaudio.com/forum/i...si&img=2674http://www.soundsolutionsaudio.com/forum/i...si&img=2676http://www.soundsolutionsaudio.com/forum/i...si&img=2677Build log is in the album and also in the build logs section.It is an amazing sub.... I have never seen that much window flex before in my life! It will be a while until I get the full potential out of it, as break in will take some time.
September 6, 200719 yr Author Ok, after messing around with the sub for a couple days, I have some info for all interested parties. My original box(sealed) was 7.57 cu ft gross.... 7.0 net after bracing and drvr displacement. It goes super low with authority in that size box, however for my taste not enough punchiness. Today, I filled the box with some wood scrap on the order of 2.1 cu ft, and the sub really loved that! It became punchier, with very little sacrifice to the low-low end. So, this weekend, I'm gonna cut down the box to 5 cu ft, and play with driver facing as well. Stay tuned to this channel........
September 6, 200719 yr Glad that worked out for you. I thought that it would when we talked. 5 cubes is very good for an 18" of that nature.
September 6, 200719 yr Author Yeah, thanks Devil, you really helped me out on that. See this is my first time messing with an 18, I've been into the caraudio thing since the early 90's, and played with 10-12-15" subs, but soon found that 10's were where it was at for me. But now, I wanted to get deeper, without having 6 or 8 subs in my trunk, so the 18 definitely fits my bill.
