Posted August 24, 200719 yr I was wondering if this amp would power 2 12 ssd good. I am on a really tight budget, and didn't know if this was a good amp or not?http://cgi.ebay.com/BOSS-CHAOS-CH3000D-300...0QQcmdZViewItem
August 24, 200719 yr Which SSD's did you get? Dual 1 or Dual 2 ohm?Why the facination with the Boss amp? Was it because it has "3000 Watts" for $170?Don't get sucked into those lies man. That amp probably won't even put out its RMS power (which is 1700 @ 2 ohms). I would say it more than likely barely puts out 1000w @ 2ohms.There are several Kenwoods and Alpine amps from that same seller that would be much better for you.
August 25, 200719 yr Author I was actually looking at the Hifonics Brutus, but seen this one was cheaper, and since I'm on a tight budget, I just wondered if it was a good amp
August 25, 200719 yr No its not. And while the Hifonics isn't a great amp, its most certainly better than the Boss.
August 25, 200719 yr do yourself a little favor, same somemore money and get what you want. dont settle for less. you wont be happy with it. all you will do later is sell the amp to upgrade if you can find a buyer. trust me. TAKE YOUR TIME.
August 25, 200719 yr do yourself a little favor, same somemore money and get what you want. dont settle for less. you wont be happy with it. all you will do later is sell the amp to upgrade if you can find a buyer. trust me. TAKE YOUR TIME. Amen to that
August 25, 200719 yr x3, it'll leave you wanting more and with those amps you'll take a bigger loss selling used. Of course you could always find a used amp.
