Posted September 23, 200719 yr Hello all A very good day today despite not hitting the 150dB @ 20Hz :thumbsdown:Here`s a few photos of my car again.Look!! I actually managed to win a U.K. Finals (I remembered to turn my amps on ) Extreme 3-4 catagoryMy scores:152.3dB @ 33Hz :earmuffs:149.0dB @ 20Hz :earmuffs: (Apparently the dB score drops on grass) Huge drop though But I`m very happy with my scores considering I`m running on half power One thing I have to say is that I will not be competing in Bass Race anymore because I have no chance of getting anywhere.WHY???Because there are no tunes (that I know off) that peak @ 33Hz for long periods of time But I`m happy trying to hit higher @ low frequencies
September 24, 200719 yr Great scores! Sorry to hear the meter didn't read as well on grass - I never would have thought that make a big difference....well, every little thing makes a difference. I know a guy who put a piece of aluminum tape over a headliner hole and gained 0.5 dB. Weird.
September 24, 200719 yr Your install is easily the best looking 150+ dB install I've ever seen... much less @ 33 hz! My truck can almost do 160 @ 48 Hz (with the seat out) -- 158.8 with the seat in -- but does about the same as your car @ 33 Hz. And it certainly doesn't look pretty *laughs*And wow... 149 @ 20 Hz... I don't think mine will even get close. I bet the car goes crazy playing that.Very impressive! If I ever make it over to the UK I've got to sit in it As for bassrace, you may have to get an Epicenter and "add" bass to do bassrace... or you can try some "Young Jeezy" -- it hits in the 30s quite a bit.
September 24, 200719 yr Author Sorry I couldn`t resist.Someone took a very nice photo of my wall.I need a new camera, I think.My main aim is to hit 150dB + 20Hz. I`ve no doubts this system will do it. Especially when they get at least 1500wrms to 2000wrms each...And if you think these subs can`t handle power?...My last system was rated at 6000wrms @ 1ohm (2x Powerbass XA-3000D) and I was running the amps down to 0.5ohm for daily listening. Played for hours - even clipped the subs for a bit & they still keep on taking all I can throw at them.As for how this system sounds?Here`s a few comments."Listening to your system has made me want to try lower tuning""I`ve never heard a system play low bass so effortlessly"These comments are from two of the U.K.s Loudest most respected Streetbassers.
September 24, 200719 yr Author Oh.I`m officially launching my ((((Propper Droppers)))) SPL testing format in the U.K. this coming weekend.I`ll be running two seperate events.One on Sat & One on Sunday.I haven`t even tested my own system using my own format yet. L.O.L.Anyway I`ll post up the results on Monday Edited September 24, 200719 yr by Mega Heavy Bass
