How much power will an Saz1500d put out at around 1 ohm in a Honda civic with a stock alternator biggest battery that fits with out mods and an optima redtop in trunk? thanks for your time and have an awesome day. Z
Edited by zedman
http://www.soundsolutionsaudio.com/forum/i...?showtopic=7116
With one battery, stock alt (about the same as the Civic in output), 1510 watts @ 12.4 volts.
With another battery, stock alt, 1635 watts @ 12.8 volts.
So... between 1500 and 1600 watts or so, give or take a few percentage :)
This battery fits in the newer Civic (this is mine). Only have to notch the battery tie-down, literally, that is ALL you need to do:
I have an older (2000) civic and it has the battery by the firewall I am not sure that will work. thanks for the info I will be talking with the with about this amp real soon. Z
I know for a FACT that the Stinger SPV35 fits in that hole (I used to have a 98 and a 99 coupe).
I bet a Kinetik HC800 would fit too, and possibly an HC1400 (but you might have to fab a new battery tray).
