Posted September 27, 200719 yr OK I made a new box (sealed) but I dont know how many cu.ft net it is? the box it the inside is 12"D 27.1/2"H 23"Wwith a driver displacement of 0.25 how many net cu.ft is it ????? help!?!?!
September 27, 200719 yr Right around 4.2 cubes internal.edit: too slow, i suck. Edited September 27, 200719 yr by J31Rob
September 27, 200719 yr Author hmmm so is that a lil to big for my MJ-18? .....edit I did not make the box I'm making the box
September 27, 200719 yr http://www.the12volt.com/caraudio/boxcalcs.asp Use this it will help you figure out what you need.
September 28, 200719 yr Admin Little less power handleing, but not by much. It should be able to play a little deeper and not need as much power.
September 30, 200718 yr how many cu.ft would a 6" round port about 13" long take up?You do realize tuning will shift when you put it in since it takes volume...
September 30, 200718 yr Author I know I just need to get an idea of how much displacement it has I'm going to port it to 31hz now I tried it sealed liked the SQ but not enough SPL sooo
