Posted October 4, 200719 yr Not much else to say here, other than after the long wait this subwoofer is definitely worth the wait. Look for some testing results in the next 2 or 3 days I believe it weighs in around 60-70lbs
October 4, 200719 yr Author Ok so its raining out and i got called in to work for the next 2 days, so i cant test today or tommorrow. GRR, anyways i did snag a couple more pics this morning before I got called ini really dont think you guys know how large this thing really is DP on left MT on rightRE 8 VS DP2 Slug SPL BTL motor VS DP
October 4, 200719 yr Author You and jim should come up and give her a listen and watch me shove a few kw down its throat
October 4, 200719 yr when you plan on actually tearing in to it? I might be free sunday if we don't end up at dave's, but saturday is beer fest
October 4, 200719 yr I have always been a fan of the 12 spoke basket, but I do really like the looks of this one too. At least Nick didnt go with a 4 spoke basket. It is possible the ugliest of all time, with the RE XXX (new style) coming in a close tie.
October 10, 200719 yr Author Sealed on the dash, 2.2 cubes 2 4" aeros tuned to 40 hz. The DP is 3db louder than the DC audio sub i tested in that same box, with the same power, but it is 20 hz higher Theres the results so far. back to workCharging batts and fixing some odds and ends withthe electrical then back to testing in a bitVIDEO HERE!!!http://www.teamssaudio.com/video/play.php?vid=136http://www.teamssaudio.com/video/play.php?vid=137
October 10, 200719 yr What amp(s) are you using to get 3000 watts at 5 ohms? 122 volts is dangerous on the outputs Thanks!Brian Edited October 10, 200719 yr by BKOLFO4
