Posted October 12, 200719 yr When I had my dodge, I had 3 TREO TSi's running from a Phoenix Gold Xenon 600.1 amp. They sounded good. Ive sold those and I am leaning towards a 15 Fi Q for my 02 monte carlo. Im wanting a daily driver great sounding Sq set up. Could somebody tell me how the 15 will compare to the 3 10's i had? For the amp, I'm leaning towards the Sundown SAE-1000D. Would the SAZ-1500D be better? The price on this website would be the highest I want to spend on an amp. My headunit is a PANASONIC MXE CQ-C8413U if that matters. Thanks for all help.Sorry this was lengthy.
October 21, 200719 yr a friend has two treo tsx 10's, sealed box. i have a 15 q in 4.8cuft ported. his subs are incredibly accurate and can get really punchy, but i like the bigger sound of my Q. and it's obviously a helluva lot louder. for sound quality i think the Q will sound fuller, but won't be quite as accurate as sealed treo subs. it just depends on what you listen to and what sound you like. one thing for sure that 15 Q will walk all over those TSi's. (i considered treo before purchasing my woofer went back and forth for a couple months, then finally started talking to guys at Fi, ordered, finally heard some Fi's at world db finals,then the decision was clear, it would be very tough to pry me from Fi now.) i can't imagine how good this thing would sound sealed, probably just as accurate as those sealed 10" treos, but it's hard to even explain how much this thing drops in a ported enclosure. if you listen to mostly hip-hop and rap then go ported, if you listen to a lot of rock and more accurate stuff then put it in a sealed box.
October 22, 200719 yr Author At first, its going to be half rock and half rap, but my main source of music is rock. That being said, I should put the Fi in a sealed enclosure?
October 22, 200719 yr Author Heres my info..2002 Monte Carlo SSPanasonic CQ-C8413U MXEStock Speakers for now with a 200 watt amp that came stock, not quite sure what I will get. I usually use Infinity Kappa's15" Fi Q Dual 2Memphis PR1.1000 Edited October 22, 200719 yr by bud
October 22, 200719 yr If you're looking for a great sounding SQ setup, you've got a lot of work in store for that
October 22, 200719 yr Author Not meaning to be an idiot, but do you mean my stuff isnt real good? lol
October 22, 200719 yr for SQ: front stage >>> subsand driver quality isn't the issue, install quality is
October 23, 200719 yr Author For the sealed box, should I stick to what the Q recommends or something different? Edited October 23, 200719 yr by bud
October 23, 200719 yr Admin For the sealed box, should I stick to what the Q recommends or something different?It is always best to start with what is suggested by Fi.
October 23, 200719 yr for good SQ you have to have somewhat good quality drivers with the best placement and having good amplifer power isn't a bad thing......install is 99% of it though
