Posted October 20, 200717 yr Which one would be better hooked up to a kole audio kx 1440 amp. and would probably be in a 1.0 ported enclosure tuned to about 33hz It will be in a Chevy regular cab s10
October 23, 200717 yr Admin I don't know much about that amp to really help much. But I feel the SSD would be more abuse tolerant than the W3 with out knowing the true output, not to mention the SSD is a great daily sub that has a good price/performance ratio.
October 24, 200717 yr that amp is 720 rms in mono. SSD, the w3 won't even take that much power, you'd need two w3's to take that power. why not a 12" SSD? if you listen to more hip/hop and rap i would highly recommend it to hit some more lows.
