Posted October 27, 200719 yr I like loud and yes the 4 Q15's Sealed in LOUD!!!!, but I think I may change up so I don't have such a huge box in the back. When I was running only 2 Q15's ported in my magnum, my boy was running the single 18" BTL ported in his Impala and we were hitting identical #'s. He was pushing the BTL with a Power Acoustic 2000 and I was pushing the 2 Q's with a US Amps MD2. We both metered 152.7 legal on an AC mic. Once I stepped up to a 4 pack of Q15's and an IA 40.1 @.5ohms, I got about a 5 db increase and alot of air movement, which makes for nice hair videos..... I guess what I am wondering is....with an 18" BTL in 8cubes ported properly and tuned to 32hz and the same power I am giving the 4 Q's, will I still be able to move air like I was? People have been coming to some of the local shows just to sit in my car and have their hair blow around..... I figure that I will be louder then what he was metering because I am more then doubling the power and giving it a bigger enclosure and more port area, but no, I don't expect to be as loud as the 4 Q15's are right now. It will be easier for me to dominate my class locally too, so I can get more trophies.What do you guys think about the change?I am typing alot because I am trying to keep my mind off of my phone just getting stolen....UUHHG!
October 27, 200719 yr I like loud and yes the 4 Q15's Sealed in LOUD!!!!, but I think I may change up so I don't have such a huge box in the back. When I was running only 2 Q15's ported in my magnum, my boy was running the single 18" BTL ported in his Impala and we were hitting identical #'s. He was pushing the BTL with a Power Acoustic 2000 and I was pushing the 2 Q's with a US Amps MD2. We both metered 152.7 legal on an AC mic. Once I stepped up to a 4 pack of Q15's and an IA 40.1 @.5ohms, I got about a 5 db increase and alot of air movement, which makes for nice hair videos..... I guess what I am wondering is....with an 18" BTL in 8cubes ported properly and tuned to 32hz and the same power I am giving the 4 Q's, will I still be able to move air like I was? People have been coming to some of the local shows just to sit in my car and have their hair blow around..... I figure that I will be louder then what he was metering because I am more then doubling the power and giving it a bigger enclosure and more port area, but no, I don't expect to be as loud as the 4 Q15's are right now. It will be easier for me to dominate my class locally too, so I can get more trophies.What do you guys think about the change?I am typing alot because I am trying to keep my mind off of my phone just getting stolen....UUHHG!1 18" btl has the same cone area as 1.5 15" btls.i would say your at a HUGE disadvantage in cone area, so i dont see a single 18" btl pulling off a hair trick or getting as loud.i would stick with the q's
October 27, 200719 yr I like loud and yes the 4 Q15's Sealed in LOUD!!!!, but I think I may change up so I don't have such a huge box in the back. When I was running only 2 Q15's ported in my magnum, my boy was running the single 18" BTL ported in his Impala and we were hitting identical #'s. He was pushing the BTL with a Power Acoustic 2000 and I was pushing the 2 Q's with a US Amps MD2. We both metered 152.7 legal on an AC mic. Once I stepped up to a 4 pack of Q15's and an IA 40.1 @.5ohms, I got about a 5 db increase and alot of air movement, which makes for nice hair videos..... I guess what I am wondering is....with an 18" BTL in 8cubes ported properly and tuned to 32hz and the same power I am giving the 4 Q's, will I still be able to move air like I was? People have been coming to some of the local shows just to sit in my car and have their hair blow around..... I figure that I will be louder then what he was metering because I am more then doubling the power and giving it a bigger enclosure and more port area, but no, I don't expect to be as loud as the 4 Q15's are right now. It will be easier for me to dominate my class locally too, so I can get more trophies.What do you guys think about the change?I am typing alot because I am trying to keep my mind off of my phone just getting stolen....UUHHG!1 18" btl has the same cone area as 1.5 15" btls.i would say your at a HUGE disadvantage in cone area, so i dont see a single 18" btl pulling off a hair trick or getting as loud.i would stick with the q'sHmm...hair trick w/ one 18, yah havent heard it done....but w/ the right specs? possibly...anyway:http://www.soundsolutionsaudio.com/forum/i...?showtopic=7153
October 27, 200719 yr Author Ok....I guess you're right. So that means I need to design a bigger box to go ported with the 4 Q15's....I have a basic idea, but I don't think it will fit, so back to the drawing board. Also, the person I have building the box wants to use 1" mdf instead of 3/4" so that affects me specs too......man, I remember when I thought 1 12" sub was loud.....what's happened to me? lolQuestion about cancellation.....I have 2 subs firing back and 2 subs firing up. Thats the only way I can fit that many in the magnum. For the ones firing up, what is the minimum distance that should be between the face of the subs and the ceiling? I dont want cancellation or to restrict the air from the back.
October 27, 200719 yr oh come on man!! go with the one 18!!! i know, i know 4 15's is impressive, big tymers "four 15's didn't see no fire...then i heard BOOM from the amplifiers!!" just got done looking at another thread where a guy hit 154 flat with an 18 btl, not sure what power here's the vid i know it's on a wall and stuff, but if ur not expecting to be as loud as the 4 15's....still don't see how you plan on saving space, that one 18 ported is gonna take a lot of space. i would put it in a 10 cube box. also hair tricks shouldn't be a problem at all. i'm moving massive air with a single 15" Q, although going to attempt hair trick, don't think it will be the best but one 18 no problem!!
October 27, 200719 yr Author I have decided......No change! Only thing different is going to be my box. I am going with 11.6ft^3 (after displacement) all single chamber with (5) 4"round X 11" long ports.It's slightly on the small side for 4 15's, but...I will obtain my goals with it.
October 27, 200719 yr I have decided......No change! Only thing different is going to be my box. I am going with 11.6ft^3 (after displacement) all single chamber with (5) 4"round X 11" long ports.It's slightly on the small side for 4 15's, but...I will obtain my goals with it.Keep the old box too, just incase you dont like how the new one sounds
October 27, 200719 yr yeh, that's kind of a smaller box but it should still sound good, i love the SQ and accuracy and of my Q 15!!
October 27, 200719 yr oh come on man!! go with the one 18!!! i know, i know 4 15's is impressive, big tymers "four 15's didn't see no fire...then i heard BOOM from the amplifiers!!" just got done looking at another thread where a guy hit 154 flat with an 18 btl, not sure what power here's the vid i know it's on a wall and stuff, but if ur not expecting to be as loud as the 4 15's....still don't see how you plan on saving space, that one 18 ported is gonna take a lot of space. i would put it in a 10 cube box. also hair tricks shouldn't be a problem at all. i'm moving massive air with a single 15" Q, although going to attempt hair trick, don't think it will be the best but one 18 no problem!!have you seen the OP's hair trick?doubt hes going to accomplish anything similar off 1 18. you need excursion for that and lots of it. you gotta get that air going in that cabin.there is only so much you can do with the 18 trying to pull a hair trick. once you reach xmax, your done. the 4 15's will move more air.sure that guy hit 154 (who knows what mic though), but off how much power? and at what note? he could be near tuning for all we know, and not getting much excursion. sure 154 sounds good, but it doesn't guarantee any hair trick, especially at 50+hz
October 28, 200719 yr oh come on man!! go with the one 18!!! i know, i know 4 15's is impressive, big tymers "four 15's didn't see no fire...then i heard BOOM from the amplifiers!!"thats "4 15's didnt see no wires" not fires LOL...
October 28, 200719 yr very true, sorry about that, I also thought about it after i posted it, i thought "that doesn't sound right" LOL oh and not the best, but I think proves one 18" BTL very possible for hair trick. Even this one i think would be better with window rolled half way up. I know I know, not huge, but I never said it could pull off a huge hair trick just saying It would be able to! lolNot sure on difference in specs from loaded BTL to MT either. P.S. that sub in the vid is only receiving ~1600 watts
October 29, 200719 yr Agree with the 4 15Q. I had 2 15Q's and it definitely loud. But I'm not sure about the 4" port though. It seems that the Q like larger port area.
October 29, 200719 yr Author Agree with the 4 15Q. I had 2 15Q's and it definitely loud. But I'm not sure about the 4" port though. It seems that the Q like larger port area.It's five 4" round ports, not one single port.Would SIX ports be louder then FIVE, or will it just cut down on port noise? My enclosure is not being built until next week after SEMA so I can still play with the calculations a bit.
October 29, 200719 yr Should be louder with more port area...That's really not enough, and why your experiencing noise...
October 30, 200719 yr Author Should be louder with more port area...That's really not enough, and why your experiencing noise...Maybe I'll go with 6 ports. Either way, it will be louder, and that's my goal, not the SQ. It still sounds cleaner the most setups at the shows down here.
October 30, 200719 yr probably becuase they're not running Fi, lol. you need to just configure how much port you need for w/e tuning you want, all this 4 ports, 6 ports doesn' t mean jack to me. remember, if it's a 4" rule of thumb is 4 inches from sidewall and 4 " off the backwall. you can't just throw those tubes anywhere.
