October 27, 200719 yr You can only strap amps that are the same modelalso the 100.4 isnt strappable, I dont know of a single 4 channel amp that is strappableBut you can use 2 SAE 1000d's strapped to your sub and then the 100.4 for your Mids/Highs
October 27, 200719 yr and i would be able to use a 100.4 linked with 2 1000d's strapped?I'm not sure what you mean by "linking" the 100.4 with the strapped pair of SAE-1000Ds. Do you mean using the RCA output on the 100.4 to feed the input on the master SAE-1000D? If so, yes you can do that.
October 28, 200719 yr Author Yeah i am sorry i did not word it correctly but i did mean feeding the input with the RCA to the strapped 1000's.
