Posted November 9, 200717 yr Hey guys! thinking of redoing my set-up and am wondering why my loudest combo would be? Items I have to work with:1300ish watts of power @ 1 or 2 ohms;5-5.5 cu ft of box spaceprice really that big of a deal seeing as I know I don't have enough for the BTL's and this isn't a real immediate idea, so i can save up for a bit. As for as my wattage and so forth, I'm hoping to not have to upgrade because righ tnow my electrical is just on the edge of supporting the amp I currenly have and if I am not thinking of getting a new alt, etc anytime in the near future.In terms of dimensions though...I can only fit one 18" of a sub, 2 15's, 3, 12's, and probably 3 10's also. Goals are: pretty much righ tnow being loud; not sounding terrible. But i've heard the BL's and thought they performed fine, so that should give u an idea of what my "requirements" are i guess. Not to picky about that. Lemme know what you guys think would work the best in terms of subs and whats gonna be loudest!
November 9, 200717 yr what amp is it exactly, with that kind of power you can run a Q or a BL, that's basically what i had to work with and i went with a Q. this thing slams, and sounds awesome cause it is their sound quality line. you could also go the BL route with extra options, or a BTL, and both of those would leave you plenty of room for an amp upgrade in the future to pound a little harder.
November 9, 200717 yr Admin It is more about the install then the choice of driver. A single 12 in the right box has the ability to put up a better SPL number then an 18 if it is not installed well.
November 9, 200717 yr Admin what amp is it exactly, with that kind of power you can run a Q or a BL, that's basically what i had to work with and i went with a Q. this thing slams, and sounds awesome cause it is their sound quality line. you could also go the BL route with extra options, or a BTL, and both of those would leave you plenty of room for an amp upgrade in the future to pound a little harder.If output is his primary focus, I might lean towards a pair of SSD 15s. Seems like the best cone ratio to power available set up.
November 11, 200717 yr looking at just box space, your ideal option would be one 15 or 2 12's, if you try to port two 15's you wont be giving them enough air space, (SSD or Q) and same for one 18, not enough air space. If it was me, I would see how much more box space you can fit, like absolute maximum dimensions to fit the box, if you can get 6 cuft, two BL 15's ported and get a second amp, of the same one you have, and you will be dropping like a mofo. with current amount of power, two 12 SSD's ported for sure.
