If you want a whizzerless, high efficiency solution, the Fostex Sigmas are the way to go, though with that Adcom you'll send them to the moon if you aren't careful.
  • Replies 50
  • Views 7k
The little black box with the analog meters in the center is an AudioSource Seven T-amp...to be honest I wasn't impressed at all. Just didn't sound...right, too harsh.
Thanks for the heads up... truthfully, I think you need some more speakers.
Those aren't mine, that's at a friend's house in NC :)
any more you would care to add?
Hmmm....
Decware, Bottlehead, Wellborne Labs, Rotel, Parasound, Marantz, Antique Sound Labs, Transcendant Sound, Audio Research, Conrad Johnson, NAD, Cary Audio, Rogue Audio, Counterpoint, Sonic Frontiers, BAT, Classe, Forte, Krell, Hafler, B&K, Bryston, Outlaw Audio, etc, etc...
They have made a lot of nice gear. The one thing nice with the Adcom amp is you can always just upgrade the pre-amp later if you want to upgrade. Integrated pieces end up as garage stereos or something later on other wise.
Just takes up more space, that's about the only "downside" I can think of.
but maybe old school quality applies as it does in car audio?
Why wouldn't it :)
Unless you have a near-infinite budget, the value of older and vintage stuff can't be ignored. Especially when there's so much mass-market crap that's being produced today.
I really like the style of some of that Marantz equipment. Would you guys be weary of buying some of the older stuff?
Something like this: Vintage Original Marantz 2270
I have an old Pioneer similar to that.
I had a remote with the Rogue 66, while it was cool I don't particularly miss it with the ARC that doesn't have one.
But then again I'm getting up to switch album sides every 25 minutes or so anyway :D
  • 3 months later...
Well, the Fostex 166/167E's are around that price, so are the 108ES Sigmas :D
But with his amp power, there's no need for high efficiency, I'll agree. The FR125's would be great here.
I started this thread 3 months ago and nothing has changed, except I'm actually able to by the stuff :P
I just can't warm up to the whizzer cone. If those sigmas were in my budget that would be the ticket, but unfortunately a little out of range :D
Nice to see the design summed up like this!
Using the dimensions I used for my BIB build:
Line length = 136"
1/2λ Fb = 50Hz
0.707*Fs(68Hz) = 48Hz
I was safe there
Vb = 29.16L
Vas = 5.8L
Qts = 0.64
20Vas*(Qts^1.25) = 20(5.8)*(0.64^1.25) = 116*0.572 = 66.352L
D/W ratio = 1.315:1
Good as well.
Driver location on baffle (So) = 36.5" from top
With line length of 68", that works out to 0.5367.
So moving on the the build itself. If you were to do it again Neon would you change anything?
I was also thinking about buying a sheet of some kind of wood, then a sheet of MDF, and use the wood on the front and staining it similar to the color of the scheme of the living room and then using the MDF for the rest and painting it black (like the scheme of the room)
But I'll probably scratch that idea when I see the price of a sheet of the wood :P, maybe some laminate instead since thats what the "wood" is in here I'm sure
Been doing a lot of work on the Design portion of the BIB Build. I have decided on using MDF and ply, with the ply stained and the mdf painted black.
Some questions I have...
1.What is the best way to paint MDF? (I believe it was Topgun who had real good approach)
2.How do yourun the wiring? around the baffle or through it?
3.What is the best place to get speaker terminal cups?
4.What sheet of ply would be best for my application?and where do you usually get it?
5.Is the polyfill from Wal-Mart good enough ordo you prefer something else?
Thanks in advance. I now have every piece planned and am hoping to get in touch with someone with a nice table saw to help make it this weekend.
1. Use Shellac, Deft, or polyurathane to seal the 'wood' then do two coats of primer then two of color. I use rustoleum brand rattle cans, but thats me.
2. I just run the wiring up and around, but you could do either way.
3. I use binding posts from www.partsexpress.com I'm a big fan of the ones with the floating slug, the ones without I have troubles of them cutting the wire.
4. For something that you are actually going to stain and finish, use oak ply, its around 40 a sheet at home depot. If it isn't a structural sheet, and just for aesthetics, I'd use something thinner, like 1/4" oak ply or similar.
5. Yep, sure is, I normally get mine at hobby lobby though.
The oak will be very important for structure but I think it will make for a much better look in the end and 40 isn't too bad
What do you mean by up and around? Up, would be going towards top/small end of the enclosure.
Shellac of Deft available at Lowes/Home Depot?
