ive got 4 12's that handle 1500 watts max a piece and a box being build to spec.i was wondering if a 1500d would b enough for as3 next year at competition.i am planning on getting a second one the year after and strapping them.im using 0 guage wire and a 100 amp fuse.ive got a factory alt. w a decka intimadator batt. under the hood.will that be enough power and can i run them at.50 oms.?im doing the 4 12's cause i just wanna upgrade amps and batts. the following year.please give me some feed back.i would greatly appreciate it..
For burps? Yes.
How many amps is the factory alternator? Not sure about daily.
For burps? Yes.
dont know bout the amps on the factory alt. but i have to play music.30 sec.what do u think itll do in dbs?thanks man.i wont play it daily.so .5 oms. cool?
I have no idea how many dBs :) That is totally install dependent.
For 30 seconds at a time you should be fine.
You don't have to play music for 30 sec. in the AS classes you have to play music until you blow your fuses or after the 30 sec., which ever comes first. You can probably get 50 amps of fuse with one 1500d depending on your impedance rise.
thanks 4 the advice!what would yall recomend when i get 2 1500ds and strap them.what electrical upgrade should i do to pound my 4 12s?thanks.
