Posted December 3, 200718 yr ive got a alpine head unit[new],and its powern off if i turn it up past 16 on vol.im running a 1500d and im hittn hard but ive never had this problem before.it skips sometimes but mainly cuts off!!!does anyone know what my problem is or do i just need a new or older radio?thanks guys and ya'll have all been a big help!!!i know its not the amp cause it doesnt cut off till the radio powers off.the only thing thats funny is it turn completely off and then powers right back on!!!
December 3, 200718 yr Author Maybe your remote lead is loose somewhere ?u mean my remote going to my amp?if so ill check.u ever known of someone haven that kind of problem w alpines?
December 3, 200718 yr Maybe your remote lead is loose somewhere ?u mean my remote going to my amp?if so ill check.u ever known of someone haven that kind of problem w alpines?Maybe I understood you wrong, the amp shuts off or the radio?If the radio... then thats different. I would check your radio wiring, sounds to me like a wire is loose and is intermittently losing connection. Probably the main power or ground to the radio. I have not heard of a particular problem with Alpine head units doing anything like that, no.
December 3, 200718 yr Author yes,its the head unit.ill check all my wiring and get back to ya soon w results.my amps doing great.its by far the best amp ive ever owned and for the money!!!!!keep up the good work man.im gettn another one soon and try some strappn to see how it bangs!!!sundown all the way!
December 3, 200718 yr what model is the alpine? mine dosen't have that problem nor has it skipped yet
December 3, 200718 yr see if your alpine has a feature to turn off the internal amp in the head unit. it won't shut off your ext amp,only power through the head unit high level outputs ,not the low levels.See if it still shuts off .If it does not shut off buy a cheap 2/4 channel amp and hook it up to your highs,mids and you should be fine.
December 3, 200718 yr I had my Eclipse do that same thing. I checked and double checked all the wiring. Ended up being the dome light shorting out when the bass hit, and cutting everything off for a second, then it would all come back on.
December 3, 200718 yr I had my Eclipse do that same thing. I checked and double checked all the wiring. Ended up being the dome light shorting out when the bass hit, and cutting everything off for a second, then it would all come back on.LOLNow thats awesome bass.
December 3, 200718 yr if u find no faults in the wiring behind radio check the speakers in the doors to see if they are "grounded out" givin its not a dead head (not sure)
