give me some info and tips bout this sub.... all help is greatly appreciated...
Aloha
Edited by yama168
like if it will get loud with the right amount of power, does it sound and play cleanly...can i get at least a 144db or higher with this sub, will it take burbs of 3000 watts.
Aloha
Thanks for everybodys help.. I just ordered 2 from soundsplinter this morning
Aloha
One of the over looked subs in the line up.
What are your box plans and power for the pair?
not to sure bout the box but i will be using a sundown 1500d or maybe 2 sundown 1500d strapped
you got any ideas for a box? let me know if you do..
Aloha
Hahaha i dunno right now i got 2 rli-8's d4 so a 1ohm final load running on a sundown 1500d. I hit a 144.6db @ 49hz car sealed, mic on the dash,
car running with these 2-8". So just maybe and definitely possible for these rli-10 can and will handle a sundown 1500d @ 1ohm and maybe even handle 2 sundown 1500d strapped.
Aloha
very true your point is taken. how bout 2-sae1000d strapped for the 10"s?. whatcha think about that? better.
thanks for your input...
Aloha
1. yes its strappable
2.was thinking maybe 1 per coil ?.
and yes it will be setup careful and properly. you got any ideas on box sizes and tuning?.
thanks for the help.
Aloha
hahahha okay my bad... not sure which amp to use now.
Aloha
i dunno just thought i be different. I will be going with a 1500d to the pair.
aloha
Since you seem pretty intent on SPL, I'd probably recommend another driver...
cool what driver would you recommend JimJ for my spl?. any suggestions would be helpful and apreceiated.
Aloha
  • 2 weeks later...
