Hi guys,
I finally have purchased all of the components for the first stage of my system except for the subwoofer. As the title says I am trying to decide on the size and box type to use. I have a 2001 Jetta and will be using Cadence amps which are very long. Earlier I was trying to fit a 15" Q in a slot port enclosure and was having a very hard time fitting everything in my trunk and still having access to my spare tire.
I have only heard sealed enclosures before, would I benefit from the larger enclosure and reduced trunk space? How would a slot ported 12" Q compare to sealed 15"? These options seem much better for my limited trunk space. What do you guys think I should do?
Thanks!
Personally I would go with the 15 and seal it, Fi suggests as small as 2.0 sealed for the 15.
  • 3 weeks later...
i dont think you will go wrong with a sealed 15, escpially if you want that tight, deep, and accurate bass
  • 1 month later...
Your right about the tight accurate bass. But deep im not so sure about. If your looking for deep, ported is the way to go.
Umm, a sealed enclosure can extend down lower, just with out the peak of a ported enclosure. The port of a ported box is for the most part a physical subsonic filter.
If you want more of a peak down low, a low tuned ported enclosure is the way to go.
