Posted January 3, 200818 yr So time to change something and it's this damn rectangular box....it's loud but takes up too much room and is uglyso instead i will make something to go on the left side and rplace thisI lost the pic of fiberglassing work but this is what came outThen The baffle and trim piecePorts, only about 9 sqaure inches per ft3 but I don't really have room for anymorecoming togetherand fiberglassing this to trim out the back of enclosure
January 3, 200818 yr Author side wall addedprobably can't tell but about 30ozs. of resin and a couple of layers of chop added to back
January 3, 200818 yr Author Got the top added Had to cut this corner out will be adding fiberglass and wood but out of latex gloves and wnna watch footballMade an amp rackAnd everything starting to come together
January 3, 200818 yr Author don't have a pic but mounted and glued amp rack then applied grill clothThen applied resin
January 3, 200818 yr Author progress seems really slow but just got done adding chopmatMUDDD.......after a couple of hours of sanding
January 3, 200818 yr Author 4 coats of primer and 2 cans of this textured stuff also added more fatmat....have a pic of that
January 3, 200818 yr Author doesn't take much roomneed to work on the paint some more the subs are beat up. Still work great but dented.....Hopefully I will be able to upgrade soon.now I got to figure out what to do hereAfter listening I need to change the port tuning (higher). Also thinking of changing out the round ports for one square one that will be removable.Will be out of town for a few weeks for work, when I get back I will so some more work to it.....just wanted to get it all in for now.
January 3, 200818 yr Very nice man , I would finish the other side off in a similar fashion to the way you did the front.
January 3, 200818 yr awesome DIY!! You did a great job. I didn't think the first box took up that much room.
January 4, 200818 yr i think i would've filled the space in front with the amp, instead of on top.but otherwise, great build.wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
January 5, 200818 yr Author Thankyou for all the kind words....Still playing with tuning and have flanges for the ports coming next week. Also am planning a plexiglass cover to go in front of the subs for protection against things hitting them and for the subs to have something to 'load' off. I noticed this week when I had a big cardboard box in front of the subs they hit better and tighter.
